LotusTalk - The Lotus Cars Community - View Single Post - A/C Stopped Working -- What to check?
post #5 of (permalink) Old 02-02-2011, 06:26 PM
glb
glb's Avatar
Originally Posted by NolanA View Post
When the temp dial is turned to maximum cold, the vents blow cabin temperature air (instead of the cold temp I expected). The temperature is the same whether or not the A/C button is pressed, but the blue light appears while the A/C is on. The temp remains the same for any number of minutes. If I turn the dial to hot, hot air blows out as expected.
did you check the fuse? Is the compressor turning? Does engine sound, rpm change when you hit the button?
glb is offline
