LotusTalk - The Lotus Cars Community - View Single Post - HVAC Fan Resistor Pack Bypass is Successful!
post #24 of (permalink) Old 06-12-2012, 12:55 PM
SirLotus
SirLotus's Avatar
Originally Posted by 407Driver View Post
I experimented with both finishing plates on, both off ..... no discernable increase in air flow, that little fan can only do so much.
Airflow meter in the dash vents and proved the airflow was appreciably higher. The fan is not undersized, rather the ducts restrict the flow.
COCKPIT VENT AIRFLOW ................RECIRC. OFF................RECIRC. ON
.................................................. ....(Outside vents open)...........(Outside vents closed)
Footwell vent closed (normal)----------27mV........................16mV
Footwell vent open (modified)----------50mV .......................45mV
There is a greater airflow at the vents with the outside air intakes open, but that air, in the A/C mode, is warm, unconditioned and could result in a higher cockpit vent temperature.Note – Higher voltage (mV) equals greater air flow
SirLotus is offline
