LotusTalk - The Lotus Cars Community - View Single Post - HVAC Fan Resistor Pack Bypass is Successful!
post #25 of (permalink) Old 06-12-2012, 12:57 PM
407Driver
407Driver's Avatar
Originally Posted by rcuser View Post
it looks clean, What did you connect the red wire to? how did you route it? thanks
Thanks, route the wire from the AC switch panel (requires drilling one hole behind the switch panel) over to the passenger side cubby (remove the cover) and you can see a space where the wire can be fed down and then forward along the underside of the dash and push the wire thru to the front side of the firewall via the main harness grommet. There is room to squeeze the wire between the firewall and the fan housing foam grommet.
Go back in the driver footwell and strip the wire, put the connectors on, install finishing plate.
LZ LoLo survivor
407Driver is offline
