LotusTalk - The Lotus Cars Community - View Single Post - DIY Blower Motor Resistor Pack Replacement
post #107 of (permalink) Old 06-21-2012, 07:36 AM
rcuser
hi, question about recharging system. ac lines are apart and capped. Will recharge with .55kg/19.4oz R134a and manifold gauges to check pressure. Do I add a separate amount of oil into the low side with the white can of PAG46? I'm changing out the drier and manual says it needs 30cm^3 of oil. How do I gauge/measure that amount to put in? Or how much do I have to add to the system total.
hvac.pdf
Also using new o rings. I'm assuming to lube them in the PAG46 oil seen below in the black container.
and any tips/advice on recharging will be appreciated, thanks
rcuser is offline
