LotusTalk - The Lotus Cars Community - View Single Post - DIY Blower Motor Resistor Pack Replacement
post #114 of (permalink) Old 07-08-2013, 03:01 PM
Ph0t0n
Ph0t0n's Avatar
I have confirmed that mouser has a typo and I submitted a suggestion for them to fix it. The 71-RH50-0.05 really is 0.05 ohms (50 milliohms).
One thing I'm confused on still...
Rob mentioned: "The new resistors were not mounted in the original position as there is no good reason to leave them there. The resistors were instead mounted next to the fuse panel for easy access."
Isn't the fuse panel out of the path of the blower where the fuses could get hot and overheat? The super expensive kit (A120P0148S) relocates the resistors inside of the heaterbox to avoid overheating. Where are you guys mounting them???
Also, does anyone know what part number is on the drier/dryer?
Ph0t0n is offline
