LotusTalk - The Lotus Cars Community - View Single Post - Elise A/C Broke - Compressor Not Coming On
post #3 of (permalink) Old 07-27-2013, 05:53 PM
XtinctElise
Saffron Yellow is Lighter
XtinctElise's Avatar
Originally Posted by glb View Post
Compressor will not kick in if refrigerant is low. While it could be a relay or fuse, this is the most common issue.
Did you ck the fuse? Note: it's never been the fuse for me...no such luck...
If refrigerant has left, and if leak can't be found, a good shop will add dye to the new refrigerant to trace the leak.
I did not realize the compressor would not even start if the pressure was low. But the fuse is also a good idea to check! We noticed the wiring the was chewed thru the tape around the radiator shroud but fortunately no wiring there was compromised.
XtinctElise is offline
