LotusTalk - The Lotus Cars Community - View Single Post - Elise A/C Broke - Compressor Not Coming On
post #6 of (permalink) Old 07-28-2013, 10:19 AM
XtinctElise
Saffron Yellow is Lighter
XtinctElise's Avatar
Originally Posted by dcat151 View Post
I just fixed the same problem on mine and the culprit was the relay. It is next to the front fuse box. The relay had worked itself loose. Once I plugged it back in and then taped it together with electrical tape (which I hope will keep it from working itself loose again), the a/c worked like a charm.
The relay was the first thing we checked and it was tight and secure. If the resistor pack went bad the blower motor would not work but it runs fine.
XtinctElise is offline
