LotusTalk - The Lotus Cars Community - View Single Post - Battery and Alternator Disconnect Switch Question
post #6 of (permalink) Old 08-25-2014, 05:41 PM Thread Starter
jasondew
A battery disconnect switch does not disconnect the alternator. The alternator can still power the ignition and fuel pumps if the ignition is switched on. The purpose of a master disconnect switch is to provide a single switch to disconnect the battery and alternator. The RLS switch is just a battery disconnect.
I was confused: I was treating my 4 wire alternator as a 1 wire alternator. Different circuit designs apply to each.
It appears that a two pole switch that disconnects the battery and the alternator's field exciter wire is what is needed. This safe guards the alternator if the switch is opened while the engine is running and the ignition is on.
Does this sound correct?
I'm thinking of using one like this:link
Will the field exciter wire be cold with the ignition off and +13v with the ignition on? Will the other wires in the alternator harness behave differently? I can't tell from looking at it which small wire in the alternator harness is the field exciter wire.
Jason
06' Fed Elise
My frame, rear subframe, steering rack, A-arms, front crash structure, suspension uprights, and fuel tank are stock.
jasondew is offline
