LotusTalk - The Lotus Cars Community - View Single Post - Question: replacing rear rad hoses at water/coolant pipes
post #4 of (permalink) Old 04-14-2015, 03:58 PM
lotus_dp
lotus_dp's Avatar
Thanks for the info... you saved me some grief. I assumed the feed pipes went all the way through. The pic makes it look that way.
Did you change your front hoses? Is it possible the push the feed pipes toward the rear of the car... enough the replace the rear hoses, then push the tubes back to the front???
lotus_dp is offline
