LotusTalk - The Lotus Cars Community - View Single Post - AC not working (but ac kicks on, and pressure is good)?
post #12 of (permalink) Old 06-17-2015, 03:40 PM Thread Starter
wek120
wek120's Avatar
The airflow is generally crappy but Im assuming its because the air is generally crappy anyways.
The air gets progressively warmer from neutral to hot, so unless the ac is stuck halfway it wouldnt make much since for it to be the flap.
Its not icing over because its just generally never cold. Id say it drops maybe 5 degrees tops.
Checked the pressure and its about 80psi neutral, then 45 psi when running, so its clearly compressing.
I dont get it, theres only so many places it could go wrong, yet all are fine....?
Theres:
Compressor itself
Activation of the compressor
Freon level
cooler and ducting
so if all are fine then it should work X(
wek120 is offline
