LotusTalk - The Lotus Cars Community - View Single Post - [05 Elise] Rainstick-like noise from the dash when turning
post #4 of (permalink) Old 07-13-2015, 05:56 AM Thread Starter
highlow
highlow's Avatar
Originally Posted by bri3d View Post
It's a black piece of wire conduit (... because Lotus) on the passenger's side front of the car, exiting near the front suspension A-arm pickup.
https://www.lotustalk.com/forums/f101/whats-tube-28416/
To access the top of the tube (HVAC box) is a brutal job (search resistor pack replacement) but the drain end of the tube should be visible if you want to try to run a wire through it or something.
I would also double check that the HVAC compartment drain holes are drilled correctly: https://www.lotustalk.com/forums/1496844-post3.html
If the noise persists, I would suspect a piece of gravel in the chassis somewhere, although I guess if it's only happening with the A/C on your drain theory is probably accurate.
I'll see what I can do about the drain plug. It seems to be working though, it drips a ton after a long drive in the florida heat with the ac on.
Were the drain holes a recall item or do all cars have them?
highlow is offline
