LotusTalk - The Lotus Cars Community - View Single Post - Elise/Exige Racing Wide-body
post #131 of (permalink) Old 08-21-2015, 11:51 AM Thread Starter
ageshelin
re: Steering wheel play
It is not the rack and pinion gear. It is definitely in the column. The column is bolted down very well. I will check, if it managed to collapse....
Are there any serviceable bushings inside the column? This is what it really feels like. Neither the .pdf or the diagram shows any internal parts in the column.
Anton
Originally Posted by Vulcan Grey View Post
There is a bushing the pushes the rack against the pinion. That might be worn/loose and can cause some slop.
There is also a spring that pushes the bushing against the rack, that should provide constant pressure, but springs give out from time to time.
https://www.lotustalk.com/forums/f259...3/#post1488513
If it is not in the rack, but higher in the column, then it could be the mounting point, or a bushing, or it could be the collapsible column is broken...
Take a look here
http://www.lotusforum.be/TO-DOWNLOAD...ering%20HF.pdf
ageshelin is offline
