LotusTalk - The Lotus Cars Community - View Single Post - Fan Speed Irregularity
post #2 of (permalink) Old 09-20-2015, 03:16 PM
kfennell
kfennell's Avatar
Your resistor for high speed has corroded out and failed. You will need to just use 2, pull the clam and condensing unit and replace them, or reach in through the drivers footwell, cut a hole, and bypass the resistor pack all together so you are always on high. Search the forums and you will find threads on all three options. Mine just did the same thing so I will pull the clam this winter and the hvac unit and replace the resistors (while moving them somewhere easier to work on them).
kfennell is online now
