LotusTalk - The Lotus Cars Community - View Single Post - Elise A/C Broke - Compressor Not Coming On
post #10 of (permalink) Old 09-24-2015, 11:57 AM
LiveToDrive
LiveToDrive's Avatar
Originally Posted by glb View Post
LTD,
1. Is wire still attached to compressor? Yes, confirmed.
2. Does that wire get voltage? Have continuity? I did not check, I'm assuming no because the new compressor does not kick on and neither did the old one.
3. We assume you checked the fuse.
Yes, I checked the AC compressor fuse under the dash, the AC compressor relay fuse in the main fuse box and I also pulled R4 in the engine bay to reset the ECU. Currently the car is sitting with the battery disconnected. Last ditch hope that after sitting dead for a couple hours the ECU will fix the issue
Also, maybe I should mention that I also have the airbag symbol dash light on all the time. Not sure how that could be related, but just in case...
LiveToDrive is offline
