LotusTalk - The Lotus Cars Community - View Single Post - Not your typical A/C doesn't work post
post #7 of (permalink) Old 12-14-2015, 05:26 AM
XM595
XM595's Avatar
That picture and prt# is for the multi function relay
I think you need the fan control relay A117M0038F
or better still B117M0038F as the some of the 06/07 cars had a bad batch of A117M0038F know as the dreaded blue relays
these were known to fail and or cause a arc flash that resets the ECU causing the car to stall
I had the same issue on my Exige the relay is located on front passenger side behind the wheel liner
New relay B117M0038F from dealer fixed all my problems
as for the smoke I think you may well have over pressurized the system and blown a seal that will need further investigation
once you get the electrical issue resolved
Here is a thread that may be useful: https://www.lotustalk.com/forums/f157...rmation-66770/
XM595 is offline
