LotusTalk - The Lotus Cars Community - View Single Post - DIY Blower Motor Resistor Pack Replacement
post #154 of (permalink) Old 01-28-2016, 04:06 AM
exigegus
I suppose it could be the same thing, but what I have seen pictured, and what happened to mine, is the main fan motor wire rots off of the resistor pack, maybe your high speed wire rotted off first.
Only alternative is the switch, so you could ohm out the wires coming off of the switch, if you can see resistance to ground then the wiring is good. Or you could swap the wires around since the lower speeds work.
Odds are its the resistor pack tho
exigegus is online now
