LotusTalk - The Lotus Cars Community - View Single Post - AC/Heater Blower Suddenly Started Working?
post #33 of (permalink) Old 07-05-2016, 11:55 AM
cyow5
cyow5's Avatar
Originally Posted by mavster View Post
perfect, I have the 10k ohm pot that I took off the temp control when I did the Tony Wa bypass. Obviously its got the right shaft on it.
Its not that its 10amp or 12amp, it's that the current drops regardless of whether I have it set to 10a or 2amp.
This unit says maximum output is 300W, that sounds like a lot but it could it be that its not enough at full power:
Input voltage : 12V DC
Maximum Output power: 300W
Maximum current: 30A
Overload Current: 60A
PWM pulse width modulation range: 0% - 100%;
Your charger though might be where the drop is coming from. Have you measured the input and output voltage at the same time? I bet you'll see they are the same and the charger just can't supply enough current, so the voltage drops.
cyow5 is offline
