When I drive to work in the morning, the ABS light comes on at start up, then after a few seconds turns off with the rest of the tell tale lights, and does not come on for the rest of the drive (about 25 min). In the afternoon, the light comes on at start up and does not turn off for the entire drive. No other tell tale lights are on.
This happens every day, regardless of the weather, for the last few weeks.
Has anyone ever had this type of intermittent problem? Does this error code get logged, in case the dealer scans the car and the light isn't on?
Yes, it was very random as in not everyday and over the corse of a year it would come on more consistently. Would throw a bunch of codes that could only be read by the official Lotus scan tool. I'm having to replace my abs control unit and possibly the lower portion as well. I'll know more once the car is up and running again. My unit looked flawless and all coils were in good condition, so I'm wondering if in fact it's lower portion that went bad. Time will tell.
I noticed today that for both back wheels I could access the ABS connectors with the wheels still on. So I opened them and applied some electrical contact cleaner.
I plan to remove the front wheels when I get a chance to clean those connectors.
I was about the remove the front wheels but then I noticed that those ABS connectors could also be accessed without removing the wheels. I just needed to angle the front wheels sharply forward and to the left for the driver's side or to the right for the passenger side.
just a follow up.
bought some deoxit and have been cleaning the abs sensor area with every car wash.
light has not returned since (about 2k miles so far).
Related Threads
The Lotus Cars Community
2.7M posts
51.5K members
Since 2002
