LotusTalk - The Lotus Cars Community - View Single Post - Cabin Fan
Thread: Cabin Fan
post #3 of (permalink) Old 12-17-2016, 02:00 PM
Reach
I agree on doing more diagnosis on if you need to look at the resistors first, as that is an extremely annoying and involved job. I just got done with it myself, with a garage and without needing the car to be working again shortly, and I still didn't like doing it.
All that said, if you're saying the car lives outside in Hawaii, then yes it is likely that the 'bathtub' which the blower housing and resistors sit in is waterlogged and has ruined the resistors or even more likely their connectors. Removing everything, running new primary wires to the blower, and relocating the resistor setup higher in the clam is the solution. Also, while you're in there, drill drainage holes in the corners of the aluminum tub area per the TSB.
Reach is offline
