LotusTalk - The Lotus Cars Community - View Single Post - Evora Power Packages are HERE!
post #38 of (permalink) Old 09-20-2017, 12:46 PM Thread Starter
turbophil
Plug Whisperer
turbophil's Avatar
Originally Posted by John Z View Post
So, the cold start issue seems to be ongoing, had pins cleaned no change. I was told swapping the harness doesn't always fix this and they believe it's a ghost imagine in the ECU causing it. The car is going back to the dealer for more testing.
An idea tossed around is to do the BOE tune to see if that fixes the cold start issue. What do you think?
Lotus struggles with cold start at the programming level. You're not likely getting any tweaks from Lotus corporate on the cold start. We've done some work with cold start, but it's really hard to tweak because you really only get one crack at it...
turbophil is offline
