LotusTalk - The Lotus Cars Community - View Single Post - First time brake pad change: loctite needed?
post #15 of (permalink) Old 10-20-2017, 03:04 PM
Pengineer91
Originally Posted by LostPawn View Post
Do you have the wheel bolts or wheel studs? Just wondering if studs still leave enough room to remove the rotor.
Bolts. Studs would make it impossible to remove the disk without getting the caliper out of the way. While you could still wiggle the inner pad out with the disk in place, there'd be no way to turn the piston back in without removing the disk.
Pengineer91 is offline
