LotusTalk - The Lotus Cars Community - View Single Post - Starting issue
Thread: Starting issue
post #3 of (permalink) Old 06-25-2019, 05:17 PM Thread Starter
waddy
By sticky relays, do you mean the mfru?
Well decided to recheck the fuses again, then tried starting it up after leaving it disconnected since I last posted this and it started up perfectly.
However a something else is happening, the alarm light on the dash is blinking very fast intermittently
and goes away when I hit around 40mph+. Instrument cluster worked fine for 20min then after starting up again it went its normal nonworking self. Also the battery light stayed when in the second ignition slot but disappeared after starting the engine, didn't happen continuously 2 in 6 startups cycles, anything to worry about?
I'll see how long this lasts me now, what on earth is causing all this. Sputtering alarm light pointing to the immobilizer?
waddy is offline
