LotusTalk - The Lotus Cars Community - View Single Post - Starting issue
Thread: Starting issue
post #10 of (permalink) Old 07-04-2019, 12:20 PM
Obeisance
Obeisance's Avatar
Originally Posted by waddy View Post
Was able to get it push started. Does this narrow it down to the immobilizer or maybe starter?
i think so. that it could be push started means that the ignition/power/trinary switch, spark control, fuel delivery and ecu controls all work. I'm not too familiar with the immobilizer, but a look at the wiring diagram should tell you if the car can run while supposedly immobilized. maybe the starter is the last remaining suspect?
that being said, i wouldn't jump to replacing it before putting a multimeter on its poles while trying to crank in order to confirm wiring continuity.
Obeisance is offline
