LotusTalk - The Lotus Cars Community - View Single Post - Starting issue
Thread: Starting issue
post #11 of (permalink) Old 07-04-2019, 01:26 PM
Jetblast
Jetblast's Avatar
Originally Posted by Obeisance View Post
i think so. that it could be push started means that the ignition/power/trinary switch, spark control, fuel delivery and ecu controls all work. I'm not too familiar with the immobilizer, but a look at the wiring diagram should tell you if the car can run while supposedly immobilized. maybe the starter is the last remaining suspect?
that being said, i wouldn't jump to replacing it before putting a multimeter on its poles while trying to crank in order to confirm wiring continuity.
I think you're right, the immobilizer appears to only kill the starter circuit. I've attached a copy of the colorized version of the 2005 Elise wiring diagram I made in case you don't have it already. Sheet 4 shows the immobilizer circuit, it sits between the starter switch and the starter solenoid (see on the right side of sheet 4 where the wires 194 and 188 go to sheet 1). It also ties into the multi-function relay unit at the fuel pump relay (see sheet 2) but I think this is only sensing, not interrupting. I hope this helps, enjoy the color wiring diagram.
File Type: pdf Elise Wiring Diagram - North American 05MY Colorized-R4.pdf (2.72 MB, 18 views)
Jetblast is offline
