LotusTalk - The Lotus Cars Community - View Single Post - Starting issue
Thread: Starting issue
post #15 of (permalink) Old 07-12-2019, 12:59 PM
Jetblast
Jetblast's Avatar
Originally Posted by waddy View Post
Going over the basics again before this, what voltage should I be getting at the ignition switch?
I'll attach some selected pages from the service manual that references some things to check. On the mult-function relay unit in the engine bay (just inboard and below the ECU), with the key in the run position, you should have 0 volts DC on terminals 4 & 6. When the key is in the run position and the start button is pushed you should have battery voltage (12-14 volts DC) at those same terminals 4 & 6.
If you don't have battery voltage at terminal 6 when the key is in the run position and the button is pushed, there is something wrong with either the immobilizer, starter switch or wiring.
If you don't have battery voltage at terminal 4 but you do have it at terminal 6 when the key is in the run position and the button is pushed, then you have a problem with the multi-function relay unit.
If you have battery voltage at both terminals 4 and 6 when the button is pushed, then you need to check the connection at the starter. At the starter, there will be a couple of wires, a large battery cable that should have power all the time; there will also be a smaller 2mm black wire, when the key is in the run position and the starter button is pushed, there should be battery voltage at the 2mm black wire.
It shouldn't be too hard to reach the multi-function relay unit from below the car if the engine access panel is removed, if you have a clam hinge you should be able to reach it from the top but it's pretty tight. The starter isn't very accessible, hence my suggestion to probe the relay unit first.
Good luck, let us know what you find.
Jetblast is offline
