LotusTalk - The Lotus Cars Community - View Single Post - Would this be bad for my Elise?
post #6 of (permalink) Old 07-30-2019, 08:24 AM
TedR
TedR's Avatar
I did not see it mentioned above, when the A/C is turned on, the radiator fans are automatically turned on to the low setting. Depending on hot hot it is outside, that should take care of all the cooling needs. If it is really hot, the engine temp may get hot enough to turn the fans on high (209 deg?)
But, like the others have said, if everything in the system is up to date on maintenance, there should be no problem.
TedR is offline
