LotusTalk - The Lotus Cars Community - View Single Post - New A052 Lotus Friendly Sizes Being Released Feb/March
post #63 of (permalink) Old 08-01-2019, 08:53 AM
LionZoo
LionZoo's Avatar
Originally Posted by ICSNO View Post
What wheels are these and are spacers required? Thank you for doing so much research on small diameter wide wheels!
Sorry, quit my job and was traveling for a bit so this is a late reply. The effective offset is +20 front and rear. The fronts are +28 from Enkei and apparently some people run them without spacers, but I found I needed one 5 mm and one 3 mm spacer to clear. The rears are +25 from Konig and you really need at least one 5 mm spacer in order to avoid contact with the suspension arm through the full range of travel (I confirmed by running my suspension through the entire range without springs fitted).
2011 Lotus Elise SC Final Edition 15 of 15 - Ardent Red
LionZoo is offline
