LotusTalk - The Lotus Cars Community - View Single Post - Help Ssc Cables
Thread: Help Ssc Cables
post #6 of (permalink) Old 08-15-2019, 07:03 PM
iana
There does appear to be something wrong in your assembly.
Should only require 3 of 1/4" ID washers and 1 of 3/16" ID washer.
Plate on gear shift lever should be drilled out so that the 1/4" dia shoulder bolt can slide right through the plate.
If this has been done then check that the length of the shoulder bolt shoulder is 5/8".
Assembly is 1/4" washer under shoulder bolt head, then through the cable rod end, another 1/4" washer, then through the gear lever plate, another 1/4" washer and a 3/16" washer, then nyloc nut.
Installation instructions are in a PDF on this page:
https://www.simplysportscars.com/sho...ossgate-cables
Vale Mr Chip 1998-2015
iana is offline
