LotusTalk - The Lotus Cars Community - View Single Post - Help Ssc Cables
Thread: Help Ssc Cables
post #9 of (permalink) Old 08-22-2019, 12:56 AM Thread Starter
Ptl92600
Ptl92600's Avatar
Originally Posted by forkmeupscotty View Post
a little hard to tell from the angle of the photos, but I'm pretty sure the rose joint of the gear cable gets attached to the gear level with a bolt and a NYLOC NUT.
The nut has a nylon insert so it doesn't come loose. In your case, the nut looks like it's barely threaded. I think you should remove the excess 'spacers' as you call them and only use the supplied amount of 'washers'.
Then thread the bolt ALL THE WAY THROUGH the nyloc. There will be increased resistance when you have to overcome the nylon insert initially.
I checked, it’s a Nyloc nut and it’s nice and snug. ’ll check everything is still in order and nicelly torked down in a couple hundred miles before I decide what to do.
Ptl92600 is offline
