LotusTalk - The Lotus Cars Community - View Single Post - Headlight cover broke. is it repairable?
post #8 of (permalink) Old 09-11-2019, 10:17 AM Thread Starter
Darren Donovan
Originally Posted by Kubera View Post
I actually came up with a simple way to repair it. No need to purchase anything.
Drill hole close to the tab location, insert zip tie into drilled hole, put zip into the clam hole and secure the zip tie with a washer. It is simple and you can always cut the zip tie if you ever need to remove the head light cover
PM me if you need any help.
I assume that the car will need to be on jack stand, and remove front wheel for any work relating to the headlight?
Thanks!!
Darren Donovan is offline
