My NASA TT1 Build - LotusTalk - The Lotus Cars Community
post #1 of 188 (permalink) Old 10-16-2013, 10:55 PM Thread Starter
Plug Whisperer
turbophil's Avatar
My NASA TT1 Build
Thought I'd toss up some pics of my 2014TT build.
Little history, BOE stuff aside, the reason I do what I do is largely about loving to study and engineer the car to get around the esses faster and more reliably tomorrow than I did today. I surely enjoy the design/build process equally as much as the driving.
I won 2012 regionals in TTU (which is now TT1) in 2012. I took 2013 off to enjoy time with my new son and prepare the car for the 2014 season. My competition has become much faster this year as I knew they would.
My plan for '14 was more downforce, more tire, better data acquisition, more safety (caged), more reliability, better cooling, and replacing the remaining wear items still on the car from 2005 when I purchased it new!
It was a lot of work. Thought I might share a few pics....
In this first set, I focused on more tire. I've not had much luck with diffs. Tried a couple and not getting to where I want with my power and sequential tranny. So this year, the diff is open. I wheeled down to 15 inchers but 10 inches wide so that I could run 275 hoosiers int he rear to help get the power down. To do this, the 949 rear wheels needed some spacing. Lathed out some billet spacers that are hub centering on the car and to the wheel. Pretty slick really. The studs are ARP and pressed in. The spacers are secured to the hubs with ARP fasteners. Not worried about strength! The wheels only weigh about 13lbs each and the spacers are about 1.5lbs... not bad!
To cover the wheels, Some reverie flares are crudely added. The car is off to the body shop this winter to make it an acceptable 10 footer--- which is all that is needed for track duty, IMO...
turbophil is offline
post #2 of 188 (permalink) Old 10-16-2013, 11:06 PM
Nice Phil!
I came about a similar solution just in the last 2 months using 15" TRMotorsport wheels and 275 Hoosiers. My wheels are only 9" wide. Had 20mm spacers made and added longer wheel studs to hold them on. In retrospect I think 23mm would be ideal. Need to get more tire to hold down that awesome REV400TVS power!
Great minds think alike, Eh!
Bill
///MD is offline
post #3 of 188 (permalink) Old 10-16-2013, 11:08 PM Thread Starter
Plug Whisperer
turbophil's Avatar
In this set, came the cage. Cage selection for the Lotus "Elige" is..... well..... pretty cagy.lol There are some really bad cages out there and few people are talking about it... I have a mandrel tube bender, and I'm reasonably handy with a TIG. I've also built a few cages over the years. They're "some work" to be sure---Something I really didn't have the time for.
After looking around and talking to friends, my buddies at VSA had that right ticket. Their cage is undeniably the hardest cage of any of them to install. That said, it is the nicest for club racing that I've seen. It's tucked in and out of the way. No ingress/egress issues with theirs and the design makes sense! They shipped it promptly. It was palletized very well. Some welding was required once the two halves were settled in the car.
I elected to remove the factory "firewall" and replace with a proper removable aluminum firewall. I deisgned the it basically as a 60/40 split. The left side is the 60. The ECU, relays, etc all hang off of it and are secured with studs and or rivnuts for easy service. The right side is the 40 side. There's nothing attached to it. It's easily removable with a few dzus fasteners providing me friendly access to the alternator, drysump, etc.
I also spaced the firewall about 5/8" off the cage tubes for easy belt routing, clearance for fasteners, and to reduce vibration. The firewall panels are ofcourse lined with edging to further help with vibration reduction.
post #4 of 188 (permalink) Old 10-16-2013, 11:11 PM Thread Starter
Plug Whisperer
turbophil's Avatar
Originally Posted by ///MD View Post
Nice Phil!
Bill
Nice Mine are 24mm. I'd be a bit concerned about running a stud so long. Perhaps when you make the thicker spacer, switch over to the way I did it. Should be stronger than running an ultra long stud, FWIW.
post #5 of 188 (permalink) Old 10-16-2013, 11:28 PM Thread Starter
Plug Whisperer
turbophil's Avatar
Cooling...
It gets darn hot in the midwest where our circuit is. In recent years, we've had well over 30 days above 100F during our track season. Humid too... ugh
So, cooling is important. My cooling system for the motor was OK, but not perfect. We learned a need for more block pressure to help reduce steam pockets hot spots. I have a friend across the pond tracking higher hp like we do and they were finding the same problem... more on that in a bit... Also needed better cooling for the water circulating through the intercooler (chargecooler, if you will) My poor car normally receives all prototype parts and this was starting to show up in its performance. So it was time to make a change and start adding some of the finished parts that BOE customers get. So we swapped out the old front mount cooler I was using for our dual pass front hex (As we call it). It's a very nice part that we had C&R work up for us and have installed in the World Challenge cars as well as several customer cars. It's extremely efficient and designed to allow adequate airflow to the engine radiator in a stacked position as you see here. (more info on that part on my website if you're interested)
The engine radiator is from Brent B. Very large rad that has been converted to single pass. We were careful to seal things up well to help ensure most all the air coming into the front of the car was forced through the radiators...
You don't see a radiator fan because I don't run one....
post #6 of 188 (permalink) Old 10-16-2013, 11:39 PM Thread Starter
Plug Whisperer
turbophil's Avatar
Some other front end items...
Some other little front end items of note...
In these pics, some little details to make my life easier.
-Mounting the remote rezzies where I can reach them even with the clam all buttoned up
-Machine and tap the back of calipers for dual top bleeders on the calipers (we have special SS lines and fittings for this in stock if anyone is interested). Also pictured are the full-floating rotors we've been using for a long time. In the calipers are still the original prototyped SS caliper pistons. No complaints on the braking
-There's no HVAC, and the battery is where the heater/AC blower would be (not in the pass footwell). I wanted the battery as far forward as possible.
-This particular setup does not run any part of the OE radiator shroud. The way you see the rads stacked above is the way it looks before the clam goes back on. It's all very simple....
post #7 of 188 (permalink) Old 10-17-2013, 12:05 AM Thread Starter
Plug Whisperer
turbophil's Avatar
Telemetry
As most know we're co-developing the stock ECU editor known as FastWorks. Fun stuff and a lot of work. We started working with AIM to develop a CANBUS template so that their dataloggers will feed off the data in the stock ECU. So I dumped the RacePak bits and switched over to AIM. No regrets as the AIM software is miles easier to work with in addition to better support from Josh at AIM.
So to be a bit different than the standard MXL Pista, I went with the more advanced EVO4 and Formula wheel
Lathed out an adapter that we then welded the FIA approved SPA stub to for the quick release formula wheel. This made the wheel plug 'n play with lotus hub. No cutting so that I can change to a GT wheel easily should I ever choose to. After racing the car, I can say that so far i LOVE the formula wheel for the Lotus. It seems perfect!
post #8 of 188 (permalink) Old 10-17-2013, 03:33 AM
Frank Amoroso's Avatar
Total gangsta! Yo!
Love it.
And it's Graphite Grey! Love it even more.
We are all very fortunate that Phil's passion is our passion. Very fortunate.
I may have started happily purchasing parts from other Lotus vendors before I purchased my car in early '06 and while I've continued to do so (hell, for a few years there I shoulda just direct deposited a portion of my paycheck into their bank accounts), I have to say that my partnership with Phil & crew at BOE has been the most rewarding. Phil originally spent two and a half hours on the phone with me, the first time I contacted him, talking me off the ledge back in 2010 when I found out my 14k mile engine had "an oil control" problem. Even after I initially decided to go a different route after that (just swapping in a used engine), Phil still provided plenty of free, friendly (hell, downright cheerful) guidance and counsel just as if he hadn't just lost a sale. Fast forward a few months, after it became obvious I didn't have the time to do the engine swap myself, I brought my car to BOE for the engine swap and a Nitron suspension install.
Then the scope creeped (mostly due to my flipping through the damn BOE catalog!)...
Rev 300 supercharger (a.k.a. the only time Phil ever up sold me. Admittedly it was a pretty big up sell, equally admittedly I was pretty amenable to being up sold, tho I did struggle a bit with the percentage increase in project cost as a result... "Uhhh yeah, Frank? This is Phil. Andrew and I are just about to install the engine in your car and we were thinking that it'd be a real shame not to put at least a small supercharger on there.").
Aero. Exige M.Y. '10 rear wing, APR CF front splitter (that Phil included a vote cf confidence cardboard template with for when I eventually tear it off so I can cut a piece of MDF to replace it with) and BOE street diffuser. I added the S111 RaceSills and APR canards after the fact.
Other items from my original 2011 build included clam hinge, 1/4 stick exhaust, etc. The hinge was the only thing I had a bit of buyer's remorse over. Then I used it for the first time and... Buyer's remorse... Gone.
I added a few BOE goodies, like SS caliper pistons and such in the interim and then decided to bring my car back to BOE for a once over and a few more goodies. My car is there right now getting de-HVACd, new radiator, front caliper brake bleeder & inlet line mod, front battery relocate, pressurized coolant swirl pot, Fast Works dyno tune, alignment & corner balance, etc.
Anyway, I didn't intend for this post to be a thread-jack / build thread for my car, so let me get to the point...
I've spent a lot of money with BOE... Twice... and I couldn't be happier about it as I've derived so much more value than the dollars I've spent. Phil, Andrew and crew are not only good people, but also great partners in this insane hobby / passion / obsession of ours. Do your car a favor and send it to BOE, at least once. Do yourself a favor and pay your car a visit while it's there. The shop is amazing, Phil's car is crazy amazing (warning: seeing it is gonna make you wanna buy shyt. A lot of it.). The whole experience is an exercise in delight.
Thanks BOE, you share my passion and you've certainly increased the units of pleasure, and pride, I derive from my Lotus and that's not an easy thing to do.
Lovefest off. Back to this thread's regularly scheduled programming...
Frank Amoroso
Fun with cars
Frank Amoroso is offline
post #9 of 188 (permalink) Old 10-17-2013, 04:00 AM
tommyc's Avatar
That looks sweet Phil. Have alot of fun with it!
Sent from AutoGuide.com App
05 elise ardent red sport touring VF1 s/c, pro rad, arquay twin, etc etc etc
05 elise GG sport touring BWR s/c Charliex s/p dent in chassis=total loss
17 BMW 428i conv wifes car
03 GMC Yukon
90 eclipse gsx 420 whp sold
04 civic si sold
13 Ford focus ST
tommyc is offline
post #10 of 188 (permalink) Old 10-17-2013, 07:34 AM Thread Starter
Plug Whisperer
turbophil's Avatar
THANK YOU FOR THE VERY KIND WORDS, FRANK!
Many more segments to the build. I'll post some more up tonight...
-Phil
post #11 of 188 (permalink) Old 10-17-2013, 12:03 PM
Vulcan Grey's Avatar
I like that the cage bar doesn't go right over the knees like all the other cages... As a tall person those knee bars scare the crap outta me!
Travis
Vulcan Grey Esprit 89 SE
Vulcan Grey is offline
post #12 of 188 (permalink) Old 10-17-2013, 12:27 PM Thread Starter
Plug Whisperer
turbophil's Avatar
One of our guys here at the shop t-boned a wall at the track two years ago in his Elise. He's tall. Telescoped his leg (tib fib) when he submarined despite having ASM belts. If there were a knee bar, he would have telescoped his femur too! So I'm with ya there!
post #13 of 188 (permalink) Old 10-17-2013, 03:47 PM
Gunpilot's Avatar
Great Job Phil!
2012 Evora 2+0 IPS.
2007 Exige mental track toy.
2005 Elise.
1982 Brunette.
"CHARLIE DON'T SURF"
Gunpilot is offline
post #14 of 188 (permalink) Old 10-17-2013, 06:11 PM Thread Starter
Plug Whisperer
turbophil's Avatar
Next was getting the cage painted and cleaning up the firewall installation.
It was important that the stock ECU fit the firewall since the '2014 plan is to be running the stock ECU in lieu of the EFI standalone ECU.
To keep things as relatively PnP as possible, the OE relay pack setup and chassis harness is retained. What a factory engine harness will work fine on this car, DRS supplied a mill-spec engine loom to factory specification.
Things are still looking pretty messy, but the vision is forming at this stage
post #15 of 188 (permalink) Old 10-17-2013, 06:28 PM Thread Starter
Plug Whisperer
turbophil's Avatar
Swirling...
I'm a fan of swirl pots for cooling...
We worked up an aluminum swirl pot for the intercooling system. It has 3/4" I/O. Then mounted on the firewall. Recall that all the mechanicals that end up on the firewall end up on the "60" side so that I can easily remove the 40 side...
The pump pushing coolant through the intercooler system is upgraded from the standard Bosch pump we normally would use to a Meziere 20gpm pump. There's no way to get 20gpm through the system, but it will still push more fluid than the standard bosch pump.
The large swirl pot for the engine cooling is unique. We've been using these for a while and comes back to the bit I mentioned earlier about block pressure. The swirl pots or header tanks replace the stock header tank all together. They're designed to swirl the entire cooling mass. This is in an effort to remove more air from the coolant than a standard header tank or a swirl tank that doesn't swirl the entire mass. Remember that coolant boils locally around the cylinder jackets and it always having more air introduced. Aerated water/coolant doesn't cool (transfer heat) as well. This system is designed to constantly rid the system of air. In addition, you'll see a schrader valve on the tank. With this, we can add additional pressure to the system to increase the "air spring" within the system and increase block pressure. We typically run about 25-30 psi block pressure. Higher pressure not only raises the boiling point, which will reduce localized boiling around the cylinders, but it also reduces the size of the air bubbles in the system to promote better heat transfer.
Below, you can see a prototype part and the final part....
post #16 of 188 (permalink) Old 10-17-2013, 06:39 PM Thread Starter
Plug Whisperer
turbophil's Avatar
Interior and motor
I wanted the interior to look decent despite the industrial and purpose built nature.
The interior shot below is essentially how the dash ended up. Using a second air bag cover, I did away with the stand cluster setup since the wheel has 4 pages of data...
The motor was my standard build. I know this motor setup well and can make about 400whp. However, I cannot run that hard for NASA TT1 after some other mods that penalized me, so we detune to about 360whp.
You see our BOE drysump setup in the pic here. This is the same drysump system that the world challenge cars, Zust's XP car, etc have ran with great success.
The REV400 TVS is pushing about 15psi boost, has stage 3 cams, Nikasil bores, port matched head, 10.5:1 Arias Pistons. Nothing too fancy.
Fuel Delivery is through our BOE surge tank....
post #17 of 188 (permalink) Old 10-17-2013, 07:46 PM
Tire abuser
jefrac's Avatar
Originally Posted by Frank Amoroso View Post
Total gangsta! Yo!
+1...!
I have been thinking that someday NASA time trials would be fun. I now see that competition might be kind of.....uh, stiff, especially in Phil's region!
Cool build, really cool.
'06 Arctic Silver Elise | Touring |Traction Control |Supercharged | ST exhaust | Nitron singles | BWR anti-sway bar | RTD brace | V2 Arms | SS brake lines | Harness bar and Schroth harnesses | sys.6.pack |shifter reinforced | Ultralite lines | cup air box | Sport inserts | DBW Pedals | TALLrails | Team Dynamics 1.2's | TOC Oil Pan | ProRad | FW Torque tune | BOE surge tank and catch can | Radium Clam Kit
jefrac is offline
post #18 of 188 (permalink) Old 10-17-2013, 08:26 PM Thread Starter
Plug Whisperer
turbophil's Avatar
Rear Downforce...
For the wing, I worked with US composites maker, Crawford (they make composites for ALMS, Indy, etc). I wanted a top mount wing to help improve the effectiveness of the foil, lessen drag, and increase DF..... and because it seemed like an interesting challenge
The uprights are shaped like that are with the points at the top to be vortex generators. One tool I don't have is a wind tunnel. lol... So in the absence of a wind tunnel, I have the several aero engineering books, some industry confidants, and my own intuition to use in the design work... So that's the reason for the Mad Max look. Same applies to the end plates. The mad max struts are tied directly to the frame through slots in the boot..
More on the wing. The wing is full width of the body and has a massive 350mm cord. The gurney flap is removable and tunable as it sits in a channel. The foil is dry layup, very light, and very strong. For the techies, the profile is a Selig 1223, which is known for ultra high lift and low Reynolds number. This is arguably the most effective profile for a race car. You won't find these features on the Chinese APR wings... or even Reverie for that matter.
The expense of the wing project was FANTASTIC. I had to commit to purchasing 4 of these. I'm still on the hook for 3 more that can be made to any width and upright dimension in case anyone is interested.... Perhaps one day I'll have the remaining 3 sold... otherwise, you're looking at a $12,000 wing right there! .... oh wait
I can only guess as to the DF this wing makes at 140mph, but I'm certain it's multiples of hundreds of pounds. I've had the car on the track as of last weekend at 140mph. Interestingly, that's 8mph faster than the car used to go on the same straight with the Reverie wing. The downforce was so great that it stretched the 4 M6 bolts/mountings that I had securing it... It has a place for 6 of them, but due to time constraints, I only fashioned 4 connection points. Obviously, I'll be revising the mounting strategy before next season!
post #19 of 188 (permalink) Old 10-17-2013, 08:38 PM Thread Starter
Plug Whisperer
turbophil's Avatar
Front Aero
While on aero, I got fixed up with Technocraft by VSA and purchased their full length 211 splitter. I obviously don't have a 211, but figured I could make it work. A few of the LCS guys are running these on their 211s, but trimmed down significantly. I'm not too worried about the aesthetics of the part at full length and figured I would be able to cleanly support it well enough to keep it full length for maximum effectiveness. To pull this off, I figured the splitter must be hung exclusively from the crash structure. In no way did I want the front clam stressed by the front aero/splitter like it is from the factory. This is also makes removal of the front clam about a 5 minute procedure even without quick releases.
So here you can get an appreciation for the size in the splitter as well as the strength with me standing on it. With the support I've added, the splitter is VERY strong. It flexes none with me walking across it even at the furthest edges. The splitter extends right at 8 inches in front of the bodywork.
post #20 of 188 (permalink) Old 10-17-2013, 08:47 PM Thread Starter
Plug Whisperer
turbophil's Avatar
Some motor pics
Since everyone likes engines...
The engine bay is actually quite clean and certainly the most easily serviced Lotus I've ever worked on...
In these pics, you'll see the swirls pots, Quaife Sequential, drysump tank, our BOE side mount oil cooler, etc... I thought I'd try my hand with the twitter app. Meh, I think I prefer the original pics rather than the "Aged" look that the twitter filter gave the engine pics... you get the idea though
I'm sure someone will ask about the breather ports being blocked off on the valve cover. When converting to a drysump system, we seal off the motor entirely-- no breather ports, dipstick, etc. This allows the scavenge sections on the pump to pull a vacuum in the crank case. The vent is over by the tank. In this pic, the vent filter is not currently installed. It's just an open tube, as you can see. Obviously a filter is placed on the tube before use.
Additionally, the tiny catch can on the roll bar strut is attached to the transmission.
  LotusTalk - The Lotus Cars Community > Motorsports > Track and Technique
