Rear dances & feels unsettled - LotusTalk - The Lotus Cars Community
post #1 of 3 (permalink) Old 04-03-2016, 09:14 AM Thread Starter
I started tracking w/a Cayman & it was always very steady & instilled confidence braking from high speed.
However, I've never felt the same w/the Exige. When braking on the main straights the rear just feels quite unsettled & dances around.
I'm running DS2500's front & rear right now, but it also did it w/the OEM pads, so what would be the normal cause and remedy?
'07 Exige S
'14 Cayman
Ridgeway is offline
post #2 of 3 (permalink) Old 04-03-2016, 10:35 AM
philethier's Avatar
Hmm. I'm no expert, but I'd try softening the rear damper rebound setting.
Phil Ethier Minnesota USA
2004 Suburban 8.1, Sport Red
2017 Ford Fusion (wife had to stop driving manual due to shoulder problem), Oxford White.
2006 Gulf Stream Conquest Super C
http://www.mnautox.com
philethier is offline
post #3 of 3 (permalink) Old 04-03-2016, 04:34 PM
forkmeupscotty's Avatar
For me, that happened only when I set the front dampers soft as that cause me to hit the front bump stops and losing grip
OR too stiff of a rebound at the rear.
OR it could be the tire pressure.
Not much else can be said since no other relevant info was given like the type of suspension, alignment, tire pressure, type of tire, etc etc etc.
2001 2JZ-GE
2008 N54B30
2008 2ZZ-GZE
2015 N63B44O1
http://www.youtube.com/forkmeupscotty
forkmeupscotty is offline
  LotusTalk - The Lotus Cars Community > Motorsports > Track and Technique
