Which steering arms? - LotusTalk - The Lotus Cars Community
post #1 of 33 (permalink) Old 07-05-2017, 04:09 AM Thread Starter
Mobius0034's Avatar
https://www.eliseparts.com/products/...ering-arm-kit/
These state only fit 5 notch steering rack but offer up to 2.5 degrees more camber plus reduced bump steer?
https://www.eliseparts.com/products/...steering-arms/
These offer up to 1 degree more camber
Which to go with or is there a better option?
Thanks
Mobius0034 is offline
post #2 of 33 (permalink) Old 07-05-2017, 04:11 AM
VisualEchos's Avatar
VisualEchos is offline
post #3 of 33 (permalink) Old 07-05-2017, 04:50 AM Thread Starter
Mobius0034's Avatar
That looks like a pretty good option. How much camber are you running?
post #4 of 33 (permalink) Old 07-05-2017, 04:52 AM
eldonz's Avatar
Originally Posted by Mobius0034 View Post
I bought these and I have a little over 2 degs of camber.
Later,
Eldon
eldonz is offline
post #5 of 33 (permalink) Old 07-05-2017, 05:53 AM
acslater's Avatar
Later,
Eldon
Same here, good kit, highly recommend
acslater is offline
post #6 of 33 (permalink) Old 07-05-2017, 06:43 AM
-2.5 in the front, but I'm lowered. I think these give -1.5 from stock just bolting them on.
2006 Exige
post #7 of 33 (permalink) Old 07-05-2017, 10:14 AM
Vantage's Avatar
I run these:
https://www.inokinetic.com/lotus/v2arms?rq=v2
Gain up to -1.6 degrees with this. I like to support the domestic businesses if possible. My track alignment is set at -2.2 front / -2.5 rear for R888 tires in stock sport pack sizes. Had to keep a few shims on there to "only" run -2.2.
'05 Lotus Elise: RS134 Monolites, Nitron Singles, Monoballs, V2 arms, RTD2 brace, Innovative motor mounts, V2 tank, GPan, Larini 8", TransCables, LumosHID, GiroDisc, Ferodo DS2500, etc.
'16 Porsche Cayman GT4
Vantage is offline
post #8 of 33 (permalink) Old 07-05-2017, 12:32 PM
jdawson's Avatar
Seems like most of these arms advertise "additional 2.5 degrees of camber" and only deliver 1.5 to 1.8 degrees extra.
Do any arms actually deliver >2.0 additional degrees?
2006 Lotus Elise
jdawson is offline
post #9 of 33 (permalink) Old 07-05-2017, 03:53 PM
Supporting Vendor
shinoo's Avatar
Yes, but only when cars are running low ride heights usually run on track-focused cars. Street car ride heights are not good for >2deg
shinoo is offline
post #10 of 33 (permalink) Old 07-05-2017, 07:37 PM
Parko's Avatar
Do you have a current recommendation on steering arms? The old arms you sold seem no longer available?
What kind of alignment and how much lower than stock LSS would you recommend for an aggressive street setup that is also occasionally driven to the track and back with no tire changes? I removed my front shims except the ABS bracket and although it tramlines a bit more, it seems to understeer less and feels more eager to turn in during autox. I had it measured and the front is only -.6 and -.8... How far is too far for the street, then?
Parko is offline
post #11 of 33 (permalink) Old 07-05-2017, 11:35 PM
forkmeupscotty's Avatar
I got -1.9~-2.3deg camber with Sector arms, which I then shimmed it back to something saner.
I think my ride height was 120/130mm. More track-focused people go lower.
2001 2JZ-GE
2008 N54B30
2008 2ZZ-GZE
2015 N63B44O1
http://www.youtube.com/forkmeupscotty
forkmeupscotty is offline
post #12 of 33 (permalink) Old 07-06-2017, 07:21 AM
jdawson's Avatar
Originally Posted by forkmeupscotty View Post
I got -1.9~-2deg camber with Sector arms, which I then shimmed it back to something saner.
Yeah - so, that's my point. I'm looking for arms that could yield -3.0 degrees and reduce bump steer (really just move steering link attachment down so I can increase 15" wheel backspacing, but hey - reducing bump steer is fine too). The Eliseparts arms advertise "Designed to offer up to 2.5 degrees more negative camber than the original steering arms", but it sounds like they only deliver -1.5 degrees of extra negative camber. I ran into the same issue with J's Racing camber joints on my S2000. Advertised 3 degrees additional negative camber and only produced 2 degrees.
Shinoo's v2 arms appear to be advertised correctly, stating -1.6 degrees more than stock, which sounds like it agrees with Forkmeupscotty's experience.
2006 Lotus Elise
jdawson is offline
post #13 of 33 (permalink) Old 07-06-2017, 05:19 PM
We're kinda hijacking the thread here, but maybe aftermarket uprights might be the solution.. There's a kit to raise the steering rack, too if aftermarket arms don't reduce bump steer enough.
2001 2JZ-GE
2008 N54B30
2008 2ZZ-GZE
2015 N63B44O1
post #14 of 33 (permalink) Old 07-06-2017, 06:08 PM
Yeah - so, that's my point. I'm looking for arms that could yield -3.0 degrees and reduce bump steer.
None of the arms will give you -3 without the natural negative camber that comes with lowering, even with all the shims removed. The only way you're getting -3 is to lower the car.
I got -2.8 out of the arms I have + no shims and lowering 17mm in the front, but I raised the car and added shims to get back to -2.2.
2006 Exige
post #15 of 33 (permalink) Old 07-27-2017, 03:12 PM Thread Starter
Mobius0034's Avatar
Went with the eliseparts ones
post #16 of 33 (permalink) Old 07-27-2017, 03:16 PM
kfennell's Avatar
Just for reference with my car about 20mm lower then stock I could only get about 2.2 degrees from the sector111 arms. To remedy this I had the uprights machined since there is a ton of meat to work with there. Now I need shims to have 3 degrees!
kfennell is offline
post #17 of 33 (permalink) Old 07-27-2017, 03:40 PM Thread Starter
Mobius0034's Avatar
Hoping I can get 2.5 with these. We will see.
post #18 of 33 (permalink) Old 07-27-2017, 05:07 PM
apk919's Avatar
Just curious as to why some people think they need more than 2.5 degrees of camber in the front...
Are you tracking your car?
Using racing slicks?
Have you tried increasing the caster?
FWIW, I track a 2-Eleven with the factory (2-Eleven specific) upper A-arms which give me -2.0 degrees of camber.
apk919 is offline
post #19 of 33 (permalink) Old 07-27-2017, 05:29 PM Thread Starter
Mobius0034's Avatar
Track yes, running r rubber, prob only need 2 degrees but want the option for more if I goto slicks
post #20 of 33 (permalink) Old 07-27-2017, 05:33 PM
apk919's Avatar
Have you maxed out the caster? FWIW, I'm not sure that more than 2 degrees (even with race slicks and stiffer springs) is going to be an improvement.
apk919 is offline
  LotusTalk - The Lotus Cars Community > Motorsports > Track and Technique
