My Elise is out of warranty now (I've had it 3 years), the alternator isn't charging the battery and LOA says it's 1700 to replace, isn't this a $200 part?
Push down on the top right there then pull. However it is super hard and I think I have had to remove the alternator before I disconnected it every time.
I put my finger on the part that faces car left and my thumb on on the part that faces car right and squeezed as hard as I can. Then a straight put towards the front of the car and it slid out easily.
Hint: When putting the alternator back in, put a loop of strong string through the top ear. This makes it easiy to hold up the weight of the alternator by pulling up on the strng loop with your right hand whilst you coax the double ears on the bottom around the ear on the block and slide in the bottom bolt. Then you can cut the string out and swing the top ear back and start that top bolt.
2005 Celica GTS uses the same alternator. This is not a huge job. Alt is right on top and reasonably accessible in the Elise. Even If I had little to no skill, I would do this myself.
Thanks for all your guidance over the years, Fred. Your advice and products have transformed my Else.
Related Threads
The Lotus Cars Community
2.7M posts
51.5K members
Since 2002
