Complete Exige rebuild - Page 3 - LotusTalk - The Lotus Cars Community
 26Likes
post #41 of 113 (permalink) Old 05-09-2019, 11:53 AM Thread Starter
Parts Finder
Partsfinder's Avatar
Just picked up the new chassis and door. Now I have 95% of the parts needed for rebuild. Will do a few things quickly on this chassis then it’s off to the paint shop to get sills painted. Can’t wait to start putting back together
Past favorites
99 Esprit
02 Eurovan Weekender
62 Falcon 450hp under 2000lbs
(My first power to weight car)
Partsfinder is offline
post #42 of 113 (permalink) Old 05-09-2019, 01:38 PM
NoRawkus305's Avatar
Unbelievable! You have done more in your couple months of owning the car than I have in almost 6 years lol. Great job! Keep it up. I enjoy reading and seeing the rebuild. Thanks for sharing.
Gabe
2002 Honda S2000 - RIP MAY 2012
2005 Lotus Elise Sport and Touring Package - Weekend Warrior
2015 NX200T F-Sport - DD and Winter Beater
2006 Hummer H3 - The wife's
NoRawkus305 is offline
post #43 of 113 (permalink) Old 05-11-2019, 03:30 PM Thread Starter
Parts Finder
Crash structure removed from new chassis. Little more damage to aluminum then I would have liked. But cosmetic in the end. Only anyone reading this post and I will have know 😂 tomorrow I hope to separate the aluminum off the good crash structure so it’s ready to go on new chassis.
Past favorites
99 Esprit
post #44 of 113 (permalink) Old 05-12-2019, 09:27 AM
DonTano's Avatar
Good progress. It looks like you are rebuilding the blue one with parts from the gray
DonTano is offline
post #45 of 113 (permalink) Old 05-12-2019, 09:30 AM
DonTano's Avatar
What are you using to glue aluminum? I am doing a small rebuild myself and just order a 3M Panel Bonding, but never worked with it before.
DonTano is offline
post #46 of 113 (permalink) Old 05-12-2019, 04:45 PM Thread Starter
Parts Finder
Originally Posted by DonTano View Post
Good progress. It looks like you are rebuilding the blue one with parts from the gray <img src="https://www.lotustalk.com/forums/images/smilies/smile.gif" border="0" alt="" title="Smilie" class="inlineimg" />
Yes that is the plan, also blue chassis is 2008 so gain a year newer and full Mohawk roof I like better. Not sure finally color yet. Plan to surprise all that are following when paint work is finished.
DonTano likes this.
Past favorites
99 Esprit
post #47 of 113 (permalink) Old 05-12-2019, 04:53 PM Thread Starter
Parts Finder
Sent you PM because at first message would not show on thread. If no one else replies with what Lotus uses I would recommend 3M body panel adhesive. 3M is used by body shops to glue on quarter panels, door skins, and more. Modern cars use this anywhere you don’t see spot welds and has been found to be structurally stronger. The type I use is black. I told you wrong price. Amazon has kit for $99 I’ve used on tin, plastic and wood so you will get a lot of uses for it just save extra mixing tips because adhesive hardens inside.
DonTano likes this.
Past favorites
99 Esprit
post #48 of 113 (permalink) Old 05-12-2019, 06:06 PM
I was looking at 3M's site and the selection of structural epoxies is staggering in working time, cure time and strengths. From what I can remember the DP 420 is the one for alum to alum allowing 20 minute working time and 24hr cure and available in a couple of sizes.
DonTano likes this.
Catsailr27 is offline
post #49 of 113 (permalink) Old 05-12-2019, 07:55 PM
DonTano's Avatar
Thanks for the reply guys, I will try those products. Not trying to hijack the tread, so back to the rebuild
DonTano is offline
post #50 of 113 (permalink) Old 05-13-2019, 03:00 PM Thread Starter
Parts Finder
Rear subframe back from powder coating. Working on mono balls in control arms now.
shay2nak likes this.
Past favorites
99 Esprit
post #51 of 113 (permalink) Old 05-13-2019, 04:41 PM
quattro574's Avatar
Looking great. Are you still on track for your track day?
quattro574 is online now
post #52 of 113 (permalink) Old 05-13-2019, 06:08 PM Thread Starter
Parts Finder
As long as painter does not slow me down I should make track day.
Past favorites
99 Esprit
post #53 of 113 (permalink) Old 05-13-2019, 06:18 PM Thread Starter
Parts Finder
Mono balls done.
Past favorites
99 Esprit
post #54 of 113 (permalink) Old 05-14-2019, 04:56 AM
eldonz's Avatar
By the way, BWR has a really nice tool for changing out the wishbone mounts. Who's monoballs did you ended up going with? I will be curious to see how long they last. It appears that under moderate to heavy track use, they don't last that long.
Later,
Eldon
eldonz is offline
post #55 of 113 (permalink) Old 05-14-2019, 05:57 AM
Race & Pamper
Kubera's Avatar
This must be a record breaker! You can start your own Lotus restoration business, you work very fast!
Kubera is offline
post #56 of 113 (permalink) Old 05-14-2019, 05:57 AM Thread Starter
Parts Finder
Mono balls from Elise Parts they are made by EP Tuning
Past favorites
99 Esprit
post #57 of 113 (permalink) Old 05-14-2019, 06:01 AM Thread Starter
Parts Finder
Haha thanks. I’ve toyed with the idea of a Lotus salvage business. I’ve been watching auctions hoping to purchase something at a decent price.
Kubera likes this.
Past favorites
99 Esprit
post #58 of 113 (permalink) Old 05-14-2019, 06:45 AM
eldonz's Avatar
I got mine from Monkey Wrench and they use an aluminum sleeve that holds the assembly. Did you happen to get a part # off of one of the bearings? I'm curious to see the specs for this bearing versus the one that came in the Monkey Wrench setup. When I replaced mine, I purchased a higher performance bearing than the originals.
Thanks,
Eldon
eldonz is offline
post #59 of 113 (permalink) Old 05-14-2019, 07:16 AM Thread Starter
Parts Finder
Very different design. These have all steel bearing you press in first then two aluminum end caps with Oring seals
Past favorites
99 Esprit
post #60 of 113 (permalink) Old 05-14-2019, 07:33 AM
eldonz's Avatar
The design is the same except the bearing used by Monkey Wrench is smaller in OD, that is why it is inside of an aluminum sleeve. That is why I'm curious if you got the part # off of the bearing.
Later,
Eldon
eldonz is offline
Similar Threads
FS: 2 - incomplete elise/exige rear brake rebuild kits Robissimo Parts For Sale 4 08-19-2016 02:06 PM
2zz-GE complete head or complete engine dallasreed Parts For Sale 1 05-18-2015 01:13 PM
Exige S1 Rebuild Tuscan Lotus Exige 536 11-29-2013 06:50 PM
Exige Rebuild: Input Welcome rosscarlson General Discussion (Lotus related) 138 09-10-2013 07:14 AM
After my nightmare of a 2zz rebuild I finally got the Exige up & running *pics* MartyMcfly General Discussion (Lotus related) 10 12-16-2012 01:40 PM
