does the AUTOMATIC PRO work on a Lotus Elise? - LotusTalk - The Lotus Cars Community
post #1 of 4 (permalink) Old 02-13-2019, 03:14 PM Thread Starter
Question does the AUTOMATIC PRO work on a Lotus Elise?
has anyone used this device on their Lotus Elise? if yes, does the OBD II scanner functionality work well on this device for pulling codes from a Lotus ECU?
EliseExiger is offline
post #2 of 4 (permalink) Old 02-13-2019, 04:08 PM
glb
glb's Avatar
last entry shows how to search, so enter the name to see if it's come up.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
https://www.inokinetic.com/lotus/re-...y=Transmission
For street cars, consider removing one or both oil coolers. Some cover them.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
https://www.lotustalk.com/forums/f320...ramming-70940/
14. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
Plus, “How to bleed brakes”:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
glb is offline
post #3 of 4 (permalink) Old 02-13-2019, 06:22 PM
He's on fire!
jds62f's Avatar
Do you need all the functionality in this device to warrant the high cost? I've got a $15 obdii reader off ebay and torque pro app, and I can pull any PID I want and wirelessly log it to boot. It doesn't have the "trip tracker" function, but if I wanted that the only person that drives my car is me, so theres an app for that too.
jds62f is online now
post #4 of 4 (permalink) Old 02-14-2019, 06:05 AM
The only even slightly weird OBD thing about an Elise is that the '05 models use the VW/Audi standard ISO 9141-2 method to get performance and fault data out of the ECU into a scanner. Most scanners try CANBUS first which is only used to communicate with the dash display. Not so good if you want to talk to the ECU about itself or the engine.
So the scanner needs to either figure out to or be told to use the 9141 protocol.
Newer 'Black dash' cars all speak CANBUS natively, so everything is just like 2004 or newer Toyota, etc.
Life gets more interesting if you want to talk to the airbag module, or do any of the custom Lotus things like actuate the ABS module for brake bleeding. But basic diagnostics and performance data are available with just about any OBDII scanner that will talk to an early 2000s VW successfully.
steelypip is offline
Similar Threads
does this work with the OBD II port on an Elise? Automatic PRO AUT-350 Connected Car EliseExiger Maintenance and Repairs. 0 02-13-2019 03:06 PM
Can I transform an Manual Lotus into Automatic Lotus? ryanchieu Powertrain (Engine, Transmission, etc) 17 04-22-2016 05:23 PM
OBDII sensor doesn't work and makes gauges not work! kfennell Lotus Exige 7 10-23-2015 11:16 PM
Pro Speed Pro 1 Polished stainless steel Exhaust kit greenjeepin Parts For Sale 0 04-27-2013 10:10 AM
Sparco circuit or pro adv race seat work in Elise?? qz5gxt Lotus "Track" and Racing Cars 0 05-29-2011 06:09 AM
