Went to get into my Elise and the driver's side door would not open. The door will lock/unlock fine. I push the door button in and nothing happens. Passenger side door opens fine.
Any ideas about a fix. I hate to drive four hours each way to fix a door. Has anyone taken the interior door panel off yet?
>>>Hello Went to get into my Elise and the driver's side door would not open. The door will lock/unlock fine. I push the door button in and nothing happens. Passenger side door opens fine. Any ideas about a fix. I hate to drive four hours each way to fix a door. Has anyone taken the interior door panel off yet? Thanks<<<
I've had it off. It's pretty simple in there. See my thread about window trouble and you can see a bit. It sounds like a piece of linkage is the issue in your case. I'll post some PICs...
Make sure that the door was not accidently locked with the key, since if it was it will prevent you from opening it from the outside even if you use the remote. You should still be able to open it from the inside.
There is sometime in the manual about how to deadbolt your doors so that the doors cant be opened either from inside or outside. Maybe you accidently did this.
I tried the key on the outside door lock. Feels as if nothing is turning inside the key drum. The key meets no resistance at all.
I did look at the manual and saw what you are referring to but no avail. I will keep everyone posted on what I find out as I take apart my brand new $45,000 car.
>>>I tried the key on the outside door lock. Feels as if nothing is turning inside the key drum. The key meets no resistance at all. <<<
It could be the "exterior lock control rod" or other linkage or the button assembly itself... I'm sure that it is something quite simple, but obviously this is exasperating and needs to be resolved ASAP.
>>>I did look at the manual and saw what you are referring to but no avail. I will keep everyone posted on what I find out as I take apart my brand new $45,000 car.<<<
The car is very simple and easy to work on - like older British cars. The inner door panel may need to be removed in your case - this is not difficult and no special tools are needed. You use the 3 mm key from the took kit along with a Phillips head screwdriver. From the diagrams I posted it looks like there may also be an access port on the side of the door that may help with inspection and remedy of this issue.
My passenger side window stopped going up all the way after a few months. It would stop about 3/16 of an inch below all-the-way-up. I fixed it in something like 10 minutes, see other thread. By properly torquing the lock nut, it should become a nonissue for me. While you are in there I would check that same lock nut as this is very easy once you have the panel off.
In many ways the Elise truly is like a street legal race car. My old Europa never stranded me, always started and so forth. But little things would come up. Once things are sorted, smiles return. If you have a cheerful can-do attitude many of them are very easy to resolve. I'm glad that I am fairly handy - it is so much more convenient to do simple stuff like this on your own compared to going into the dealer and waiting or leaving the car. Imagine if you had to wait until the maid comes next Tuesday before you could get a new bath towel or toilet paper roll.
Personally I am fine with the Elise NOT being as worry-free as a Toyota Camry. To make it so, the Elise would have to cost 2-3 times as much. Lotus would have to robotize the assembly, redesign parts to accomodate this, buy robot spray booths, etc, etc. When you have to raise the price for things like that it drives sales volume down so there is a vicious circle in that there are fewer cars over which to amortize the huge capital investment. So in a sense Lotus subsidized the car by making it prone to little aggravations so that we could even get the car in the first place.
My daughter had gone into my car to see if she had left her running shoes in it. But the door would not open. The keylocks went up and down when you pressed the fob button... but nothing when you pushed on the lock.
I could open the door from inside (crawling in through the passenger door).
Doing a search on Elisetalk, I found this thread.
Turns out, my daughter had locked the car with the key manually. And this (to everyone here's amazement!) disables the door handle.
Now, if you put the key in and turn it... nothing happens. As the original posted noted. But if you turn the key and then press the handle button WITH THE KEY... it opens and then returns to normal use.
the same thing happened to me, driver's door wouldn't open from the outside. i tried it about 20 times during the day, no luck. the next day, after doing absolutely nothing, it worked fine.
Yep,
You absolutely can't open the car with the key if it was closed with the fob. They even mention in the manual only way to open the car closed this way with no power is to charge and/or replace the battery.
Chris
Yep,
Chris
Yikes! Does this mean if the vehicle is in an accident (where power is lost) and the door was locked from the inside that you couldn't get out of the car? I know that the door handle doesn't do crap if the locks are engaged.
Good question,
Don't know, I was just thinking in terms of activating the locks when parking. Check the manual in the alarm section I think, it explains what happens. From the dim recesses of my mind they specify the door lock(where the key goes) can be turned perpendicular or parallel with the ground and this has some affect as to how it locks. Again, don't remember the specifics tho.
Chris
You're able to manually pull up on the lock levers on each door. It takes quite a bit of effort, as it's directly engaging the motorized locking mechanism (I think), but the manual says you can do this.
One really must wonder how Lotus managed to engineer such a contraption...it's a design that's been worked out for decades now, you'd think they'd look at how most other cars do it.
I was wondering the same thing.. in a car prized for simplicity and purity of function, we have door locks that need four pages to explain?
I read it twice and still don't understand all the different permutations they can get into. If I ever have a dead battery, at least the trunk will open so I can get the manual out and study up on how to open the car.
Truely bizzare, but so long as I use the key fob to lock/unlock, then there are no key scratches on the door either.
I'm sure that they sourced the parts/mechanism from some other manufacturer that uses them on their cars. It's common for them to do so - it's much cheaper to buy the parts (ever with strange quirks) than to design and manufacture them.
I don't consider it a problem, as I don't ever expect to use a key to lock the door - I'll use the fob to arm the alarm (and incidentally lock the doors), otherwise I tend to leave convertibles unlocked so that the thief's don't cut up the tops to break in and find there is nothing in there to steal anyway...
Umm couldn't you just lift the pin
FWIW, I read the manual and realized that the door manual locks a completely redundant so I don't intend to ever use them
I was thinking the same, until I noticed (from a restaurant booth) that some people will actually try the door to check inside! They're taking pictures and stuff, so I fully expect they would have seated themselves like some kind of showroom.
They didn't seem the type to go slashing the roof, so I have to think the locks were useful there. Some people just have no sense of property or courtesy.
You mean you can pull up on that little tab?! Actually, I tried to pull up on it the other day and I couldn't get it to come up. I didn't really try to hard, and I didn't have any fingernails that day.
I'm used to my BMW's which always unlock the door on the first pull, then open the door on the second.
TRY IT!!! I did, and thought I was going to break something so I stopped and decided to ask my service dept. about it.
I usually prefer to drive around with my doors locked, but as long as I don't do that in the Elise I don't see this every being a problem. Could be a nice anti-theft technique, if nothing else.
You could also use this feature to lock the doors while you are away, and prevent any other family members from driving the car. Unless, of course, they knew the secret. So, shhhhh.
Related Threads
The Lotus Cars Community
2.7M posts
51.5K members
Since 2002
