Evora throwing CEL P0034 - Need Advice - LotusTalk - The Lotus Cars Community
post #1 of 1 (permalink) Old 07-14-2019, 03:13 PM Thread Starter
mirage's Avatar
My 2010 Evora is throwing a P0024 code for "B" Camshaft Position Sensor - Timing Over-Advanced or System Performance (Bank 2). I'm not sure where the Bank 2 sensor is located at, but I do know that my temp has been a bit high lately. I thought it may just be "because its Florida and its hotter," but maybe not. Freeze frame is below. Where should I start with this Check Engine Light? Does anyone have any experiences they can share when dealing with this?
Potential failure modes:
Static valve timing is incorrect
VVT camshaft actuator failure
VVT control valve stuck open / closed
VVT control valve filter
Vehicle Manufacturer: Lotus
Vehicle Calibration ID: A132E0044
Freeze frame information:
Fuel Status = 0 byte
Engine Load = 45.098 %
Engine Coolant Temperature = 204.8 F
Fuel Trim Bank 1 Short Term = -2.344 %
Fuel Trim Bank 1 Long Term = 0.781 %
Fuel Trim Bank 2 Short Term = 5.469 %
Fuel Trim Bank 2 Long Term = 1.562 %
Engine RPM = 1,722 rpm
Speed (OBD) = 9.321 mph
Intake Air Temperature = 113 F
Mass Air Flow Rate = 20.1 g/s
Throttle Position(Manifold) = 21.961 %
Run time since engine start = 1,258 s
Fuel Level (From Engine ECU) = 47.843 %
Engine Load(Absolute) = 33.725 %
Commanded Equivalence Ratio(lambda) = 0.1
Relative Throttle Position = 7.843 %
Absolute Throttle Position B = 54.902 %
Accelerator PedalPosition D = 34.51 %
Accelerator PedalPosition E = 17.255 %
mirage is offline
