I'm working on some winter maintenance items and have the rear clam off. There are still some plumbing items I want to clean up and some other items that have a very tight fit between the engine and the firewall. Items like changing the thermostat, installing a block off plates and just the plumbing for coolant/oil are a very tight fit if not impossible to change with supercharger fitted and AC/Alternator in the way. I've seen a couple photos of custom firewalls, attached what I could quickly find to give an example. Has anyone removed the stock firewall and put something else in? I'm assuming there is a good amount of disassembly first but could pay off once done. Can the firewall be moved up or reshaped in a way to provide more access? Even an extra inch or two could be huge and I'm not sure that would really hurt cabin space. Anyone have any good pictures of such an install? Tips or tricks from someone that has done this? I have an Exige with the intercooler so not worried about losing the rear window.
The bottom one is phils old car where it is two pieces attached to the roll cage. I am planning on doing the same myself, but waiting until I get a full cage in to do it. Likely sometime this year. I don't see any reason you couldn't make a firewall off he back of the roll cage in the same manner, just have some boxes off it where the harnass bar etc is?
Yes, that is Phil's old car and I took the pic from his website.
I was hoping you'd chime in as I expected you might be undertaking this at some point. I wasn't sure if this would need to attach to a roll cage or harness bar or if it could attached to the stock locations and simply have more bends build into it. I'd want to keep it simple enough but haven't seen many pictures of one to know how it fits around the fuel pump, harness bar, roll cage, etc. Also not sure how big of a project this is, is it engine out or just seats out. I'm assuming it is worthwhile if it provides more room but many I'm wrong and it's not worth the time.
However how to mount it in an in between way I really dont know. I never really looked how the firewall is mounted now. You would need to avoid the harnass bar, but the roll cage is pretty far forward, the fuel pump opening is there, but you could make a part removable there.
I would think best bet is to attach to the top of the roll cage with a few spacers, then come down on whatever angle lets you avoid the harnass bar. And to use a harness bar that just uses the holes on the back of the roll bar, not the seat belt holes.
Related Threads
The Lotus Cars Community
2.7M posts
51.5K members
Since 2002
