HID lights adjustment - LotusTalk - The Lotus Cars Community
post #1 of 4 (permalink) Old 05-29-2019, 05:35 AM Thread Starter
Imba80's Avatar
Hello, so I am wondering if anyone knows how to adjust or can give me tips on how to make the lights properly fitted to face straight instead of crossing each other. Thanks in advance for your help!
Imba80 is offline
post #2 of 4 (permalink) Old 05-29-2019, 07:23 AM
Less is Better
me73's Avatar
Corrective glasses?
What car and year?
me73 is online now
post #3 of 4 (permalink) Old 05-29-2019, 01:37 PM Thread Starter
Imba80's Avatar
Originally Posted by me73 View Post
Corrective glasses?
What car and year?
I just bought the car. 06 Elise
Imba80 is offline
post #4 of 4 (permalink) Old 05-29-2019, 02:36 PM
glb
glb's Avatar
See last entry on how to search. BTW, did you even try a search??
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k. As of this writing LEDs are not as good.
5. Transmission:
The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
And, use:
https://www.inokinetic.com/lotus/re-...y=Transmission
For street cars, consider removing one or both oil coolers. Some cover them. Oil doesn’t get hot enough on street, leading to cam wiping.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
https://www.lotustalk.com/forums/f320...ramming-70940/
You NEED a digital multimeter (voltmeter) to work on modern cars. Handy around house too. Get one this week.
14. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
Plus, “How to bleed brakes”:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
glb is offline
