Note that many people disagree with my method, so judge for yourself.
Taught to me by semi-famous Toyota engineer, who built championship winning cars and bikes.
1. Get Sears brake bleed kit (canister, hoses, adaptors for bleed valves) and their hand vacuum pump. Kits there have both components. Inexpensive.
2. Pour a little b/f in canister, hook up hoses and use the tightest adaptor you can.
3. Pump vacuum to 20-25” with bleeder valve closed.
4. Tap caliper with small hammer or similar. This releases the air bubbles clinging to the caliper into the stream. WHATEVER method you use, DON’T skip this step.
5. Open bleed valve.
6. When vacuum is almost gone, close bleed valve.
7. Check level in master cylinder. Do this often.
8. Repeat as needed.
Benefits:
*Never got a firmer pedal using any other method.
*Requires only one person. Your wife/so will thank us both.
*You will not be pushing the piston in m/c into the rough area normally unused, thereby not prematurely wearing that seal. (Clutch m/cs are always used to full range.)
Note: On my Elise, I needn’t even remove the wheels.
Yeah, yeah, people use pressure bleeders, but my racecar mechanic friends don’t like these.
Yeah, I know about speed bleeders.
The above is my opinion. No responsibility for screw ups, injuries, maiming or deaths.
Is the sears kit universal and how much did it cost? I'm using the motiv kit and it works great but not a fan of buying new caps for my other cars so I do it the old school way for those. Very time consuming.
Typically in a fluid-delivery system it is best to have the higher pressure on the side where you want the fluid to go when there's a leak. If you would rather air be introduced into the liquid lines in the event of a leak, you want the liquid to be at a lower than ambient pressure. If you want the liquid to leak out instead, put it at higher pressure. When changing brake fluid, I prefer to see the leak and avoid introducing air into the system so I like to put it under pressure.
In my 25 years as a mechanic I never heard of air bubbles clinging to the caliper but not saying that it couldn't happen.
I replaced the master cylinder and hydraulic booster {$$$} on my S6 Audi and it feels like I have air trapped somewhere even though I bleed it numerous times.
The pedal pumps up but on first push sinks pretty low. Think I'm going to give it a try. Thanks for the tip glb.
why on earth not,they do exactly as they are designed to do,never heard such rubbish,ive been in many pit garages and they all use them
I was in sebastian vettel's garage during the melbourne f1 grand prix this year and they were using one lol
dont you need to turn the front calipers upside down to bleed them properly due to their design unless you use a pressure bleeder
Everytime I needed to use the pressure bleeder it was usually empty because the person who used it before me was to lazy to fill it up.
Once when I went to use it of course it felt empty. As a precautionary measure I alway's removed the Schrader valve to relieve any pressure on the bladder no matter what.
One day after replacing the master cylinder on my old Audi 80Q, tired and just wanted to get out of the shop I didn't do that. I looked at the gauge and it was reading '0' not thinking safe I opened it.
Brake fluid shot out like a geyser in my face and went all over the place. -eek- NEVER trust what the gauge reads.
Just in case anyone comes across this thread rather than another- for regular bleeds I really don't think you need to turn the calipers upside down. If you've introduced air into the system, either from letting the fluid in the M/c get too low or because you're trading the lines for SS ones, absolutely rotate the calipers.
FWIW. I had air in my system. I bleed with pressure a few times, didn’t fix my problem. I used vacumm last time and all good.
I didn’t rotate or tap the calipers.
That's good, and not the first time it was the answer. Even after installing new lines, I didn't have to rotate caliper. I did tap, tho. NOT in Morse Code.
I retired my Elise a few years ago and have a fairly new Motive Power bleeder model 0100. $30 obo.
Related Threads
The Lotus Cars Community
2.7M posts
51.5K members
Since 2002
