Hi guys,
Quick question:
After having my transmission out, my clutch pedal is seriously soft and does not disengage the transmission properly.
A quick investigation revealed a puddle of brake(clutch) fluid under the car. when the pedal is pressed, fluid runs out from what appears to be a valve (the black thingie in the picture) in the rear clutch pipe.
So I have 2 questions:
1: Is this fixable without replacing the pipe and the valve? (Not the end of the world to replace: https://deroure.com/partinfo.asp?MAK=1&MDL=12&TBL=6060&SMA=0&SMO=0&ST=&SC=0&PBID=244948)
2: Seeing as I have spilled a fair amount of fluid onto the floor, I need to at least top it up, and if I replace the pipe it will need to be bled. Where is the reservoir? From the parts schematics it looks like it shares a reservoir with the brake master cylinder?
Quick question:
