Mocal (Laminova) heat exchanger with Accusump - LotusTalk - The Lotus Cars Community
post #1 of 10 (permalink) Old 11-14-2013, 03:02 PM Thread Starter
BANNED
I've finally eviscerated the twin oil coolers and lines then installed the Laminova heat exchanger to cure my oil line recall problem.
The first thing that had to go was the sandwich plate with the thermostat. Good thing that Mocal made the one that Lotus uses so a MOC-SP1 was a direct replacement. The center thread was re-used and the one supplied was not used. I also got the Mocal 1/2" BSP x -10 fitting - 1 Pair for the sandwich plate. I got those from here. Sandwich Plates - Mocal Sandwich Plates
I got 5 each of the 90-degree fittings and 1 each straight in AN-10 size from here
Red and Blue Reusable Fittings
I got a 10-foot section Aeroquip SS line from here
Stainless Steel Braided Hose - -10 Aeroquip Stainless Steel Braided Hose
This is heat exchanger that Lotus uses in their kits with 32-mm push-on fittings and -10 AN thread-on for the oil side.
Laminar Flow Oil to Water Heat Exchangers - Mocal Laminar Flow Oil to Water Heat Exchanger- Medium with Push-On Hose Water Connections
All that is needed for the engine bay is two more hose clamps to hold in the heat exchanger in the water return line. Just cut an 8" section out of the hose, and away you go!
Up front, the Lotus kit also includes a ProAlloy, 3-pass radiator...here is a single pass radiator in the same dimensions that I've used.
Pro Alloy Motorsport - Specialist alloy components - Lotus Elise,Exige,340R,211,Europa Alloy Race Radiator
Up in the right, rear wheel well is where I routed the OEM "T" and check-valve for the Accusump. Never mind the drop light...you don't see the drop light at the top of the engine...
Just so you know who designed the head on these cars...
Here is where the heat exchanger resides...looking forward at the firewall.
I tried to get a better shot of the sandwich plate...but...
ALSO!!!! This is a big gotch yah!!! The inlet and the outlet of the Mocal thermostat sandwich plate is backwards from the Mocal plain sandwich plate.
And here is looking deeper up through the engine, off to the right side where the two -10 AN lines go up to the right rear wheel well.
<@@> is offline
post #2 of 10 (permalink) Old 11-14-2013, 04:45 PM
I am interested in what oil temps you see now compared to the old front radiators... as I will be installing my Laminova soon....
da40flyer is offline
post #3 of 10 (permalink) Old 11-14-2013, 05:10 PM
re: Sources for Aluminum fittings
Just FYI.
There are some great sources for race parts in the mid-West.
Summit ann Jegs and also Motor State. I find their prices very competitive. Pick the one that offers free shipping.
I used to run Aeroquip exclusively with special fittings from Earl's. I watched XRP get better and better. I use XRP, now. There are a bunch of knock-off's and no-name brands, now...
Anotn
P.S. If You were going to run a sandwich plate, must as well switch to better external filter. See Canton or System1.
ageshelin is offline
post #4 of 10 (permalink) Old 11-14-2013, 11:29 PM
Gunpilot's Avatar
Looks great JJ!
2012 Evora 2+0 IPS.
2007 Exige mental track toy.
2005 Elise.
1982 Brunette.
"CHARLIE DON'T SURF"
Gunpilot is offline
post #5 of 10 (permalink) Old 11-15-2013, 02:10 AM Thread Starter
BANNED
I don't have a temperature probe...
It looks like Lotus went to good sweadgedon fittings but spiced into the good line to "T" in the Accusump...they just used those Oetel clamps and that was the one that was leaking for me...here was the OEM setup...and the soarce of my leak!
So my main purpose was to fix the leaking oil and to relocate the oil radiators from the most vulnerable part of the car (the forward outboard corners) and put it in the safest part of the car (on the firewall).
<@@> is offline
post #6 of 10 (permalink) Old 11-15-2013, 02:13 AM Thread Starter
BANNED
Originally Posted by ageshelin View Post
Just FYI.
Anotn
I've purchased from Jegs before and have drooled over Summit's catalog... I guess having an aerospace engineering background, I went with the tried and true AN fittings...I know they work!
Yeah...I know about the oil filters...Its just that I bought 10 of them and now just using them up...not going on any tracks yet, but when I do, I'll stick on a big'un.
<@@> is offline
post #7 of 10 (permalink) Old 11-15-2013, 02:17 AM Thread Starter
BANNED
Originally Posted by Gunpilot View Post
Looks great JJ!
Thanks! In this low 50s high 40s temperatures we are having here in Cincinnati, I got soaked in oil and antifreeze...what a PITA to do!
But I did let it idle until the coolant temp got up to 98C so the fans would come on and then back down to 94C when they cut off. That was a good 45 minutes! Temperatures got real stable and I checked for leaks...none to be found!
<@@> is offline
post #8 of 10 (permalink) Old 11-27-2013, 09:02 AM
Apex_in_sno's Avatar
Almost exact setup I've got.
Around town dinking around, coolant is stable at 195, oil temp is 180 to 190.
On track coolant again 190 to 195, oil temp 220 to 250.
VFII, Eliseparts Sequential, Geartronics Paddle shift.
You name it, I've probably got that installed too...
1864lbs, full tank
Otherwise, it's bone stock....
Apex_in_sno is offline
post #9 of 10 (permalink) Old 12-19-2018, 09:53 AM
chiarov's Avatar
I've looked very closely at the new sandwich plate and I don't think this is correct. Anyone else care to comment and confirm or deny?
2012 Porsche 991.1S white
2014 Audi Q5 3.0T scuba blue
chiarov is offline
post #10 of 10 (permalink) Old 12-19-2018, 01:14 PM
CRG53's Avatar
With the Mishimoto plate installed on the engine, and you on your back looking up at the plate, the right hand side (also the driver side on left hand drive cars &#129299 is the outlet.
Boe REV 300 Supercharger.
Boe DMC Ultimate header.
Boe Clam Hinge.
Boe Pro Alloy Radiator.
Boe TOC wet sump oil pan.
Boe Fuel surge tank.
Boe Oil catch can.
Boe HP fixed rotors with Ferodo DS 2500 pads.
BWR Larini Group B Muffler.
BWR Street/Track Anti roll bar.
Mocal rear mounted oil cooler with fans.
V2 steering arms,
Nitron Singles 425/550.
InoKinetic DS rear toe links.
CRG53 is online now
