My Dash Removal Instructions - LotusTalk - The Lotus Cars Community
post #1 of 96 (permalink) Old 03-31-2007, 07:57 PM Thread Starter
buzzy's Avatar
I took my dash apart today for fun and to also find some clips that were sliding around inside.
1. Disconnect Battery!
2. Pull Passenger Airbag Cover off.
Pull it directly towards you.
You'll break 4 plastic clips which will need to be replaced.
3. Remove steering column cowling.
Remove 2 screws from the bottom and 4 from the sides.
Pull the bottom part downwards and disconnect the trip reset button cable. A small pick or eyeglasses screwdriver inserted into the clip will release it.
Pull this piece off, it's loose:
Now time to remove the upper cowling. It's held on with 4 metal clips (highlighted in blue, 2 on each side) and some velcro (green).
Lift the back of the cowling up to the sky to loosen the velcro, then pull the whole thing forward towards the back of the car. The metal part of the clips might fall into the dash but you should be able to get those later.
Here's what the metal clips look like, all the remaining parts are held on with them and screws.
4. Remove center vents and radio
If you want, you can use the radio removal tools to take the radio out first. I don't have mine so I took this part off whole.
Remove the 3 or 4 screws (highlighted in red) and then pull the piece directly towards you, it's held on with one clip (blue)
5. Side sills and side vents.
The side sill and side vent is all one piece.
Remove the small screw towards the back of the side sill.
Lift up the rubber mat and remove the 2 screws at each side:
Remove these 2 screws:
Pull out the plastic trim that holds the start button and disconnect it.
The vent area is held on with 2 clips here:
Lift the side sill up from the rear and pull back to release the 2 clips. It might be stuck down so pull it.
Do the same for the other side.
6. Loosen Tachometer
To get the dash top off you'll need to loosen the tachometer and lean it towards the back of the car.
7. Remove Dash Top
It's screwed down with 4 or 5 screws.
Lift up slightly and disconnect the speakers.
Pull towards the back of the car to remove.
Finished:
Overall I wouldn't say this was too hard at all, I was pretty scared to do it but it ended up being a lot of fun.
I hope this is useful for some people.
Luke
buzzy is offline
post #2 of 96 (permalink) Old 03-31-2007, 07:58 PM
Forum Founder
Randy Chase's Avatar
Great post Luke. Thank you.
#somethingwickedthiswaycomes... the new Origin Noble M and the Origin 7
Zenos E10S for Sale! www.zenosforsale.com
There are some very shady dealers in the Lotus business.
2005 Lotus Elise, 1993 MR2, 1995 MR2, 125cc Shifter Kart, Toniq (in build), 2018 Origin 7 (waiting), 2018 Origin Noble M (waiting)
Randy Chase is offline
post #3 of 96 (permalink) Old 04-01-2007, 06:23 AM
Jim-C's Avatar
Excellent work, thank you.
Jim-C is offline
post #4 of 96 (permalink) Old 04-01-2007, 06:51 AM
www.theapexinn.com
kestrel74's Avatar
So, you were one of THOSE kids who took everything apart !!!! ( did you ever put it back together ???????? )
Elise #2292 (SOLD) / CO / Starshield / Nitron Sport SA / RTDbrace / Uprights machined / Down Low rails / DBA 4000 Wiper Slot Rotors/ V1 / SS lines w/Pagid Black / G-Pan / Odyssey PC680 with RLS Bracket / Difflow 5 Element diffuser / Stebel Nautilus horn
www.theapexinn.com
kestrel74 is offline
post #5 of 96 (permalink) Old 04-01-2007, 07:20 AM
The Stig's Avatar
Looks good, just a bit of info if you remove pretty much everything you are going to take out about 47.3 lbs... :
http://www.elisetalk.com/forums/show...4&postcount=54
Neil
WTF people?
The Stig is offline
post #6 of 96 (permalink) Old 04-01-2007, 07:48 AM
JnC
JnC's Avatar
Mods: I think this should be stickied
2007 Cross Country Travelblog
11 Lotus Elise Final Edition :: Chrome Orange
16 Honda CR-Z EX
76 Porsche 912E
95 Porsche 911
JnC is offline
post #7 of 96 (permalink) Old 04-01-2007, 08:46 AM Thread Starter
buzzy's Avatar
Thanks, if I knew this would be so much help I would have taken more pics.
I just went for a drive and forgot how this thing rattles over uneven roads. I would highly recommend anyone doing this go get some sticky backed felt from craft store and stick some on the bottom of the dash top before you put it back in.
Luke
buzzy is offline
post #8 of 96 (permalink) Old 04-01-2007, 09:05 AM
Not the admin anymore
RacyTracy's Avatar
Gee, you can drive it with that broken wheel???
RacyTracy is offline
post #9 of 96 (permalink) Old 04-01-2007, 09:25 AM Thread Starter
buzzy's Avatar
Yea it kinda wobbles from left to right when I hit 85mph!
buzzy is offline
post #10 of 96 (permalink) Old 04-01-2007, 10:51 AM
Chococar's Avatar
Thanks for the informative post.
Chococar is offline
post #11 of 96 (permalink) Old 04-01-2007, 11:30 AM
wrh3's Avatar
Thanks for the post, I have filed this away for the future It's a good time to have the dash covered in leather......
Bill
'11 Lotus Elise (Traded) , '05 Lotus Elise (Traded)
www.billswebspace.com/lotus
www.syntheticfirst.com
wrh3 is offline
post #12 of 96 (permalink) Old 04-01-2007, 07:36 PM
Probably Lurking
Keeper's Avatar
Nice write-up. I added it to the reference section of uberpost.
-Shawn (2005 Elise) || New England Members of Lotus Ltd. (NEMOLL) - PM me to join local info list or NEMOLL || UberPost - Elise/Exige info: common problems/fixes, etc.
Keeper is offline
post #13 of 96 (permalink) Old 04-01-2007, 09:38 PM
mike325ci's Avatar
for fun, eh? haha. maybe you have some top secret CF replacement dash project coming along? confess!
Mike | Manhattan/LI, NY, USA
'01 325Ci ("daily" autox track), '86 MR2 (autox track) for sale, '92 Celica GT-Four (restoration show autox rallyx), '07 Exige S (autox track)
Laser Blue / Magnolia, Track, Touring, LSD/TC, SS. HRM: HID, 6pt.Schroth. Voltphreaks 3.5lb Battery, DRL Disable
"What's my quarter-mile time? I dunno, I turn before I even get that far..."
mike325ci is offline
post #14 of 96 (permalink) Old 04-01-2007, 10:04 PM
raggedy1's Avatar
did you find any loose clips/screws/rivets rolling around back there???
It's Delux son, Delux. It's not that hard.
http://itsdeluxson.com/
raggedy1 is offline
post #15 of 96 (permalink) Old 04-02-2007, 07:58 AM Thread Starter
buzzy's Avatar
Yea I found plenty of broken airbag clips. All my metal clips were accounted for but when I went for a drive last night I heard one sliding about so I'm going to take it apart again to retrieve it and also insulate all plastic contact points with felt. It'll be a good time to hardwire my V1 too.
I've no secret project going on!
Luke
buzzy is offline
post #16 of 96 (permalink) Old 04-03-2007, 08:57 PM
Luke
Perfectly timed for me as well. The dash has minimal impact on chassis stiffness (riveted into car) so I'm thinking that I'll drill a couple of holes to allow the next popped clip to fall out. Haven't done this yet and may not after I see the design without the dash cover on.
I'm pulling mine as soon as I get the replacement airbag clips to install the V1 remote display in the vent panel just over the radio. Looks like I may have to go without the clip in the center.
Is removing the radio a requirement for removing the center panel?
Thanks very much for posting this.
ken
Ken Wright is offline
post #17 of 96 (permalink) Old 04-03-2007, 09:27 PM
Serebo1's Avatar
The radio - in its housing - will pop out when you remove the center panel.
Matte Black, Sport, Touring, ***** intake (TBA), RAC Mono wheels, Painted Shift knob, smoked turn signals, Alpine SPS 6.5" rear speakers, MB Quarts, JVC Nav, Starshield, LBH exhaust, Dpic perf. gauge, Custom true HID projectors, GUT wing and splitter, Mesh side pods, Sector111 harness bar and 4-point harness, Lotus Sport Ohlins double-adjustable suspension, swaybar, '06 LED tailights, Toda flywheel, Lotusport interior.
Serebo1 is offline
post #18 of 96 (permalink) Old 04-04-2007, 06:35 AM Thread Starter
buzzy's Avatar
Yea the radio and center piece will come out as one.
buzzy is offline
post #19 of 96 (permalink) Old 04-04-2007, 06:59 AM
Thanks, I have the radio removal tools and plan to pull the head unit out first, thereafter it sounds like the sleeve will come out with the vent panel.
Again, thanks for taking the time to post this.
ken
post #20 of 96 (permalink) Old 05-06-2007, 07:39 PM
Do you have to get the air bag clips from the dealership? How much do they cost?
westmc is offline
