Stock: “Excuse me”
Stebel:
“HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
a) Early cars have wobbly shift towers. Look up Stan’s Mod (bolt and spacer;
http://www.billswebspace.com/ShifterReinforcement.pdf) and
https://www.inokinetic.com/lotus/re-enforcer?category=Transmission
7. Rear toe-links can loosen and break with disastrous results. You can check tq periodically, or use Nordlock washers. Best is conversion to better engineered brace, such as BOE’s for one example.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
Some on this site are a bit obsessed with hockey pucks for lifting the car. Don’t use these. Too hard and slippery, generally, and too small a surface area. Use a piece of wood, as your hero does.
13. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
14. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
Plus:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
