New owner, First maintenance - LotusTalk - The Lotus Cars Community
 3Likes
  • 1 Post By glb
  • 1 Post By khamai
  • 1 Post By machine.gun.kelly
post #1 of 13 (permalink) Old 03-04-2018, 07:51 AM Thread Starter
I purchased an 05 Elise (18k miles) last fall. Its been sitting in storage since and I want to get the car ready for the year. Looking at maintenance records from the previous owner, doesn't seem like the car was touched or even driven much since 2014.
Here's what I have planned so far:
- Oil & oil filter
- Brake fluid, pads
- Gearbox oil
- Coolant
- Air filter
- Tires
Stock radiator seems to be okay, don't think I need to replace that yet. And battery has already been replaced.
My question here is - am I missing anything? Any other consumables I should replace, or any failure-prone parts I should check?
Thanks
jambas is offline
post #2 of 13 (permalink) Old 03-04-2018, 07:54 AM
glb
glb's Avatar
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
https://www.inokinetic.com/lotus/re-...y=Transmission
7. Rear toe-links can loosen and break with disastrous results. You can check tq periodically, or use Nordlock washers. Best is conversion to better engineered brace, such as BOE’s for one example.
https://www.lotustalk.com/forums/f311...-u-tube-47232/
https://www.lotustalk.com/forums/f320...ramming-70940/
Some on this site are a bit obsessed with hockey pucks for lifting the car. Don’t use these. Too hard and slippery, generally, and too small a surface area. Use a piece of wood, as your hero does.
13. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/e...ow-here-25131/
14. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
Plus:
https://www.lotustalk.com/forums/f101...brakes-241138/
How to Search:
jambas likes this.
glb is offline
post #3 of 13 (permalink) Old 03-04-2018, 08:16 AM
khamai's Avatar
And check this vid from the GGLC.
Cheers,
Kiyoshi
jambas likes this.
Lotus events in California - www.gglotus.org
khamai is offline
post #4 of 13 (permalink) Old 03-04-2018, 05:05 PM
A few additional points to consider:
Replace the batteries in the key fobs, then re-sync. This helps to avoid issues with arming/disarming the alarm as well as central locking.
I wouldn't worry about the brake pads unless they're worn or contaminated. Brake pads don't age just sitting there.
When you bleed the brakes, remember that the clutch uses the same reservoir. Bleed the clutch first.
Unless records show it's been done already, you have a 13 year old accessory belt. Add that to the list.
Pengineer91 is offline
post #5 of 13 (permalink) Old 03-06-2018, 04:13 PM Thread Starter
Thanks all for the information, appreciate it
Good point with the pads, those seem to have plenty of life left.
jambas is offline
post #6 of 13 (permalink) Old 03-06-2018, 04:29 PM
CRG53's Avatar
Check to see if the oil line recall has been done, if unsure call Lotus USA with your vin number in hand, they will be able to tell you.
Boe REV 300 Supercharger.
Boe DMC Ultimate header.
Boe Clam Hinge.
Boe Pro Alloy Radiator.
Boe TOC wet sump oil pan.
Boe Fuel surge tank.
Boe Oil catch can.
Boe HP fixed rotors with Ferodo DS 2500 pads.
BWR Larini Group B Muffler.
BWR Street/Track Anti roll bar.
Mocal rear mounted oil cooler with fans.
V2 steering arms,
Nitron Singles 425/550.
InoKinetic DS rear toe links.
CRG53 is online now
post #7 of 13 (permalink) Old 04-17-2018, 10:48 AM
I'd also make sure your tires are OK.
FWIW i had been putting off replacing the radiator on my 06 exige, but it just sprung a leak last weekend. Luckily, it was after the event while i was unloading the car from my trailer once home, but i guess it goes to show they can go bad at any time.
+1 on the oil line recall.
Also check the suspension bolts for torque. https://www.lotustalk.com/forums/f91/...iagrams-95601/
have fun
Knowledgeispower is offline
post #8 of 13 (permalink) Old 05-06-2018, 06:29 PM
Good list. Maybe also go through bushings and suspension conponents and grease anything that looks worn, change wiper blades, and dont forget to wash/clay/wax and he car
Whats a good shop in southern cal to perform these services?
Beemerb0y is online now
post #9 of 13 (permalink) Old 05-06-2018, 09:22 PM
Sig
machine.gun.kelly's Avatar
Replace the wheel lug screws with BMW screws. They are lighter and you can throw away that special wrench...also saves weight! Then you can use any 17mm socket for your lug wrench.
Go dig out that tool and a take a close look at it. I bet you that it is already plasticly deformed where the 6-point star meets the shank. It will fail. It is not a question of "if", but "when". Save yourself any future headaches by replacing the lug screws ASAP.
Lotus Elise Modification, Installing BMW Lug Nuts
3carmonte likes this.
Whoever said that island life is great was never committed to Alcatraz...
machine.gun.kelly is offline
post #10 of 13 (permalink) Old 05-07-2018, 06:23 AM
`08 Elise-SC-220
3carmonte's Avatar
Thumbs up
Standard shank length on the wheel bolts is 26mm. This source was posted by another member recently and is a dependable vendor. https://www.ecstuning.com/b-ecs-part...iABEgIw7fD_BwE.
P.S. Drain and flush that old rancid window washer solution! (Another gem I learned in here). I think it's in the video as well.
Shhh...Secret Squirrel
3carmonte is offline
post #11 of 13 (permalink) Old 05-07-2018, 03:09 PM
Here is a run down of pricing for these services (southern cal, indipendant shop- are these prices fair??)
Engine oil and filter using Motul 0W40 and Toyota filter $125
Transmission service using Redline MT90 $110
Radiator flush using Toyota OE coolant $110
Brake fluid flush using Motul RBF600 $125
OE Drive belt $200 parts and labor
OE Air filter $85 parts and labor
Alignment $90
post #12 of 13 (permalink) Old 05-07-2018, 07:00 PM
Alignment $90
The engine oil change, transmission fluid flush, brake fluid flush, drive belt and air filter service all sound kinda high. Each one of these can be done, in your garage, on jack stands (you don't need a lift) with tools you probably already have. The air filter and drive belt services are fiddly PITA's, but can be done yourself.
The radiator flush is more time consuming than $110 in labor will cover. At least, if it's going to be done well.
Alignment sounds ok. Results are dependent upon the skill of the tech doing the work.
post #13 of 13 (permalink) Old 05-07-2018, 08:02 PM
I really dont have the time between work and kids.. so if these prices are fair, ill have it done.. just got the Lotus, so not sure what service prices are, im used to BMW M cars, which cost me nothing but tires and oil changes, contrary to all the fear of issues depicted online
