Can someone point to the infamous Stan's shifter mod thread please? I am helping a friend sort his Elise and I need to get him a copy of the mod. As always, thanks a bunch!
Thanks guys! Wasn't there a second re-enforcement mod also available? I appreciate the help. Had a long day yesterday facilitating the run and then the maintenance day until dark today. I am beat and can't think straight! But I still have promises to fulfill. Once again, thanks for the help!
I did my stiffening job tonight using a brass pipe as the spacer. A pipe is far easier than a stack of washers. I found it easier to install if I loosened the 2 nuts at the front of the shifter, allowing me to slightly lift the whole housing. See pictures below.
Note: You might want to increase the bolt length to around 45 mm. I would have like to do that but ~40 mm was all I had.
I did Stan’s mod and makes a big difference. I did have to enlarge the hole under the hand brake area with a step bit, but other than that pretty straight forward.
Thinking of doing this mod - has anyone used a piece of PVC pipe in place of washers/machined brass pieces/steel junction? Seems like it would be strong and light.
I did one of these can't remember the sizing but really you are just looking for something to give extra support to the space between the floor and the shifter unit where the bolt will go through the middle and thread in.
You can just cut some schedule 80 PVC to length and it will work fine. Light and won't have potential for galvanic reaction.
Related Threads
The Lotus Cars Community
2.7M posts
51.5K members
Since 2002
