-   Maintenance and Repairs. (https://www.lotustalk.com/forums/f101/)
-   -   Trunk won't open... need help please! (https://www.lotustalk.com/forums/f101/trunk-wont-open-need-help-please-12316/)
jasperw4 05-06-2011 02:15 PM
Originally Posted by RacyTracy (Post 1591012)
Really wasn't intending to be a smart-ass....just that the solutions I knew involved getting to the pull handle without damaging the vehicle.....once the handle is removed, like Michael, I do not know a solution. Sorry.
sorry, thanks for trying. just a bit frustrated that someone was in the exact same scenario as we are and posted a solution and now we can't get it. we called the local dealer and got back "just break it". guess we'll figure something out. thanks tracy and michael.
tesprit 05-06-2011 04:59 PM
PMed you. Don't start breaking things yet! :panic:
Michael here 08-17-2016 04:00 PM
I have the same problem and have been trying to get in now for days. Could someone please share with me th secret to getting into the trunk like bob did. Hint I have already tried pulling the lever...
dartim 09-09-2016 10:09 AM
I have this same issue with my Elise. The key turns about 45 degrees in either direction, but the latch won't disengage. I've tried pulling the handle too with no luck, so I'm assuming the cable is broken/disconnected. Any help would be greatly appreciated!
wfink 09-09-2016 10:21 AM
Fellow LT'rs, David is legit. He purchased my 2005 Elise a few weeks ago. I never had this problem with the car so can't help him out. Can someone email him the solution? Thanks!
Snowphun 09-09-2016 12:12 PM
Wish I could offer help, the spatula approach was stressful and didn't work for me. In the end my car was at the dealer for a few hours, fixed under warranty and didn't act up again. Good luck.
wfink 09-11-2016 12:31 PM
Any luck yet?
dartim 09-12-2016 07:00 AM
Yes, I did figure out how to get it open. It wasn't quite as easy as I've seen suggested, but not too bad. If anyone else has this issue please PM me and I'll explain how I did it.
wfink 09-12-2016 08:38 AM
Congratulations. Had me worried.
philethier 09-13-2016 05:33 PM
Can't pm you. You don't have enough posts.
dartim 09-15-2016 07:36 AM
Sorry, didn't realize that rule about that. I could also email an explanation if that works for you.
philethier 09-15-2016 07:45 AM
I have it open. Went in through the louver and removed the latch pin. Details later.
synulose 11-08-2017 09:43 AM
Could someone please pm me about how to get the boot open on my 2008 Elise SC? The key turns in the look but will not unlock the boot. I tried pulling the emergency pull tab but broke off without any result.
glb 11-08-2017 07:46 PM
Push down on lid while turning the key.
Does it feel like lock is broken?
Obeisance 11-09-2017 03:20 AM
that sounds to me like something is broken. if i recall correctly, the mechanism is something like this: the key stalk is attached to a lever arm at it's base. this lever arm pulls on a cable that actuates the latch release. however, the point where the cable attaches to the latch release consists of a cast metal elbow that acts as a hook to pull the latch. this hook is held in place by a delicate plastic clip. if the plastic hook breaks then the cable will come loose and will not actuate the latch. at that point turning the key or pulling the safety release (which just pulls the keystalk lever from it's other end) will have no effect to release the latch.
in that event, i expect that the way in would be to release the latch mechanism assembly from the engine cover lid. there are four nuts, two in the engine compartment and two in the trunk compartment, that need to be removed in order to do this. I'm not sure how accessible these nuts are without the engine cover lid open, though.. something might have to be broken to get to them.
Doug Bordonaro 05-08-2018 03:56 PM
My trunk lid is stuck closed also. The key only spins about 1/4 of the way like normal, but the trunk won't unlock even if I put some pressure on it. Can someone share the method of opening the trunk without the key please?
ERDoc74 04-29-2019 06:13 AM
Mine has this issue since yesterday.... Can someone post the fix or PM me?/??
Thanks in advance!
