WHAT IS THE ELISE RED LINE AT? - LotusTalk - The Lotus Cars Community
post #1 of 20 (permalink) Old 03-19-2009, 08:12 AM Thread Starter
RENDERMAN's Avatar
What is exactly the Elise rev limit, I've heard 8500 RPM, 7800RPM but some times i get the red light indicator at 6000RPM in low gears. Is this a gas saving indicator? some times I step on the car and this light throws me completely off, I'm all confused....Please explain
"I take life one pixel at a time"-RENDERMAN
Adobe Photoshop CC and Autodesk Maya Certified Instructor
WILL.I.AM
My work:
http://www.wilsart.com/
RENDERMAN is offline
post #2 of 20 (permalink) Old 03-19-2009, 08:15 AM
LARRY's Avatar
Good question, there's no red line on the tach!
The red light means red line. SHIFT.
Around 8000-8500 rpm max.
Sometimes less when the car is cold, the computer doesn't want you to go quite so fast.
At those times, the rev limiter is keeping an eye on you and keeps you to 6000 rpm.
LARRY is offline
post #3 of 20 (permalink) Old 03-19-2009, 08:15 AM
Tracktimeplz's Avatar
Its a 2 stage rev limiter, the 6000 rpm is for when the car isnt warmed up sufficiently. 8500 is the fuel cut for the main rev limit.
STOP BEATING ON IT WHEN ITS NOT READY
2003 Honda S2000 - Suzuka Blue
2005 Magnetic Blue Elise
Forcefed 275 turbo - Sold 05/20/09
Tracktimeplz is offline
post #4 of 20 (permalink) Old 03-19-2009, 08:15 AM
apk919's Avatar
The ECU limits the revs to 6000 RPM until the engine coolant gets up to temperature (I believe at 70C or 158F). After that, the redline is 8500 RPM for short bursts and 8000 RPM continuous.
Certain CEL modes will also limit engine RPM...
apk919 is offline
post #5 of 20 (permalink) Old 03-19-2009, 08:16 AM
richw350's Avatar
1. Redline for quick bursts is 8,500 rpms
2. I beleive that if you are at redline for more than 2 sec. it is 8,000 rpms (can someone confirm?)
3. If the car is not warmed up, it will not let you go past 6,000 rpms (keeps you from going into the hi-cam)
Hope this helps.
edit. Damn, apk beat me to it.
Richard Williams
2011 Persian Blue Lotus Evora
2011 Starfire Pearl Lexus IS350 - Sold
2006 Chrome Orange Lotus Elise - Sold
richw350 is offline
post #6 of 20 (permalink) Old 03-19-2009, 08:33 AM
www.theapexinn.com
kestrel74's Avatar
wow....they should put that in the MANUAL !!
Elise #2292 (SOLD) / CO / Starshield / Nitron Sport SA / RTDbrace / Uprights machined / Down Low rails / DBA 4000 Wiper Slot Rotors/ V1 / SS lines w/Pagid Black / G-Pan / Odyssey PC680 with RLS Bracket / Difflow 5 Element diffuser / Stebel Nautilus horn
www.theapexinn.com
kestrel74 is offline
post #7 of 20 (permalink) Old 03-19-2009, 08:37 AM
def
def's Avatar
That was a close finish, but it looks like Tracktimeplz walks away with the Gold after winning by just seconds
V10 R8 · Noble M400 · GG Elise (sold after 1192 days and 22961 miles)
def is offline
post #8 of 20 (permalink) Old 03-19-2009, 08:37 AM
fun4two's Avatar
actually I think most of that information is in the manual. When I test drove a used elise I hit the limiter at 6,000 and thought the same thing, actually didn't buy the car beacuse I thought the limiter was supposed to be at or around 8,000 and that this car was messed with. Oops, the elise I bought was nicer anyway.
Steve
2006 Graphite grey Elise
You only get one time around in life, if your not enjoying what your doing, why do it at all? Enjoy every second like it was your last, you never know!
Oh yeah and drive it like you stole it!
fun4two is offline
post #9 of 20 (permalink) Old 03-19-2009, 08:45 AM
OSX Black hat
charliex's Avatar
There are three 'standard' rev limiters on current cars, 6000 RPM , 8000 RPM and 8500 RPM
Black Exige S / Elan M100. Don't run a smaller pulley without an upgraded fuel pump! http://www.goth.am ecu stuff.. New reflash box coming soon!
charliex is offline
post #10 of 20 (permalink) Old 03-19-2009, 12:44 PM Thread Starter
RENDERMAN's Avatar
Thanks guys very intuitive. I'll set my Tach to 8000RPM to be safe and make sure the car gets to the right temperature before I launch next time
WILL.I.AM
My work:
post #11 of 20 (permalink) Old 07-14-2012, 05:16 AM
Kramit's Avatar
Dammit! And all along I thought something was wrong with the car... Replacing plugs, filters, greasing up the coil packs.. This is important to know. Seems like sometimes it takes a while to warm up then! But I'm glad this is the answer to my "problem".
Kramit is offline
post #12 of 20 (permalink) Old 07-14-2012, 06:00 AM
AboutTime's Avatar
Did any of the 05 cars have a fuel cut off? After letting a buddy drive mine and screaming "Shift! Shift! ShiftDammit!" I've been wondering about a cut off or buzzer.
2005 Lotus Elise, de-Hass'd. RLS mini-mirror, MWR Lift Point Kit, Homebuilt cup holder, Radium Clam-Kit, Sector DSbrace, and gPan, generic Deka ETX20L, hard engine mounts to stop the exhaust from breaking again. Adding Lightness by dieting, and reducing lap-times by adding seat-time.
2018 VW GTI, 6MT, White over plaid
AboutTime is offline
post #13 of 20 (permalink) Old 07-14-2012, 06:10 AM
addertooth's Avatar
Yes, the 05 has the same rev limiter characteristics. 6000 cold, 8000 rpms normal, 8500 excursion for 2 seconds before fuel cut-off.
addertooth is offline
post #14 of 20 (permalink) Old 07-14-2012, 06:26 AM
Gamera The Atomic Turtle
komiko's Avatar
i actually wait till 186 degreees, then another 5 minutes to get the oil hotter before engaging warp drive. And i think when the car is warming up, the oil temp LAGS the water temp, and ideally, you want the oil temp in the 250's. One of my oil coolers was removed from the loop, helping me to raise those too low oil temps.
Lotus Elise #134 - S O L D BOE REV400 street car built at BOE in KC. , Stock motor, low boost w/stock cat/mani, 292whp, (5.95 lbs/hp) passes all 50 states emissions/OBD, BOE ST exhaust, ACT HDSS, BOE Clam Hinge, BOE Oil Cooler Relocation, BOE Surge Tank/750cc injectors, BOE Race Links, MWR Rear Lift Kit etc. 0-100 = you bet!
Build thread :
https://www.lotustalk.com/forums/f160...seline-114302/
komiko is offline
post #15 of 20 (permalink) Old 07-14-2012, 07:21 AM
How do you get it that hot? When I'm regular driving it sits around 175*-180* at the most.
nate379 is offline
post #16 of 20 (permalink) Old 07-14-2012, 08:50 AM
addertooth's Avatar
You are from AK, build a bonfire on your radiator.
post #17 of 20 (permalink) Old 07-16-2012, 08:20 AM
AboutTime's Avatar
Fuel cut off does work, but only after a while. It's not nearly as intrusive as my WRX's.
post #18 of 20 (permalink) Old 07-16-2012, 09:48 AM
malakaone's Avatar
This is the temp I usually get at too. If my oil is at 200+ I am beating on it.
malakaone is offline
post #19 of 20 (permalink) Old 07-16-2012, 10:00 AM
philethier's Avatar
I thought there were thermostats on the the oil coolers. Are you saying that you could not get your oil up to the oil thermostat setting?
philethier is offline
post #20 of 20 (permalink) Old 10-06-2018, 01:30 PM
rev limiter
My Elise 2007 rev limiter still at 6500rpm at 196 F after 30 minutes everything is perfect with my motor... I have the Vison function stage 2.
Thanks
Frankiron9 is offline
