What the Heck! Push in throttle, no response, just idles. - LotusTalk - The Lotus Cars Community
post #1 of 21 (permalink) Old 10-10-2012, 09:25 PM Thread Starter
Title says it all. Im trying to do a coolant flush and pump coolant through the system. I started the car to do so and wanted to raise the RPM's upward of 2k to get the temps up. I go to push the gas pedal with my hand and nothing, no throttle response whatsoever. What am I missing here?
Also, Peak Global 50/50 is recommended correct (in the gold bottle)?
Also, searched all over this site for a good DIY on coolant flushes. I cant find one that explains things very well and I hear its a real PITA on these cars. Any links youd guys suggest?
MartyMcfly is offline
post #2 of 21 (permalink) Old 10-11-2012, 12:35 AM
Motorcitydak's Avatar
Uh oh, ill start with is your check engine light on? Which of your ecm's is in control of the throttle. If you could, post up a pic of your throttle body and throttle pedal just to make sure they are stock
Do you know what all things your stand alone ecm controls?
Motorcitydak is offline
post #3 of 21 (permalink) Old 10-11-2012, 03:39 AM
SirLotus's Avatar
SirLotus is online now
post #4 of 21 (permalink) Old 10-11-2012, 05:38 AM
Such moderate
Doge's Avatar
You have an 06 right? So its an electronic throttle?
Doge is offline
post #5 of 21 (permalink) Old 10-11-2012, 05:40 AM
doug_porsche's Avatar
hoping it an 05 and the cable just came loose.
Apexes are a lot like relationships. So tough to get right, so easy to see where they went wrong.
The secret to a long life is ------- not dying.
doug_porsche is offline
post #6 of 21 (permalink) Old 10-11-2012, 06:19 AM Thread Starter
yes, its an 06, so drive by wire.
stock TB & stock Pedal. CE Light is on due to test pipe, but dont have a scanner to check codes...ARGHH. I think the stock ECU controls idle, and the Stand alone controls throttle response.
Thanks for the link Michael.
post #7 of 21 (permalink) Old 10-11-2012, 07:54 AM
Plug Whisperer
turbophil's Avatar
you have an older 1.2 EFI as I recall... If it's a X2, it will have "X2" printed in big white lettes on the front of the case.
With the 1.2, the STOCK ECU controls all aspects of the throttle and idle speed. The EFI only controls fuel and spark/cam timing.
If throttle is not working, then you have a wiring issue going... You should be pretty familiar with that problem by now... sorry, couldn't resist
turbophil is offline
post #8 of 21 (permalink) Old 10-11-2012, 09:05 AM Thread Starter
the ladies in this gif remind me of me and the rest of lotus forums, the guy in the clip reminds me of turbo phil.
post #9 of 21 (permalink) Old 10-11-2012, 09:49 AM
Call up the local auto parts stores to see if they rent the diagnostic code scanners, or find someone in the area that has one. Your check engine light is on because of the exhaust but it may now have other reasons for being on as well. You may also have a wiring problem too, which is going to be loads of fun!
post #10 of 21 (permalink) Old 10-11-2012, 10:27 AM
Such moderate
Doge's Avatar
I bet this issue is related to the other issue. Trace the wires at the tps back, see if any of them are fried.
Doge is offline
post #11 of 21 (permalink) Old 10-11-2012, 11:03 AM Thread Starter
Where is the throttle position sensor located? I wonder if I got that bad boy plugged in
post #12 of 21 (permalink) Old 10-11-2012, 11:32 AM
Such moderate
Doge's Avatar
On the throttle body. Black little box with usually 3 wires going to it. But the electronic throttle bodies may have more wires.
Doge is offline
post #13 of 21 (permalink) Old 10-11-2012, 01:06 PM
Vulcan Grey's Avatar
Where's Captain Picard when you need him?!
Travis
Vulcan Grey Esprit 89 SE
Vulcan Grey is offline
post #14 of 21 (permalink) Old 10-14-2012, 02:53 PM Thread Starter
So I took out the plug too the throttle position sensor, noticed a few bent prongs on the inside of the sensor. I straightened them out and pushed the plug back in (I dont get that snap like you normally do with your other plugs).
Anyhow, if I have the TPS plugged in, the car wont start. If I unplug the TPS plug, the car fires right up. Also, the TPS is making a loud, noticeable mechanical hum with the plug plugged in. What the heck!
Any suggestions?
post #15 of 21 (permalink) Old 10-14-2012, 02:57 PM
Such moderate
Doge's Avatar
Sounds like more fried wire problems.
Follow the wires from it and check 'em all.
Doge is offline
post #16 of 21 (permalink) Old 10-14-2012, 03:01 PM Thread Starter
According to your wiring diagram..what fuse is this running to so I can do another good christian Resistance test.
post #17 of 21 (permalink) Old 10-14-2012, 04:38 PM
Such moderate
Doge's Avatar
The wiring diagram I have is for an 05 with a cable throttle and the tps doesn't run through any fuses. All the wires run to the ecu.
Doge is offline
post #18 of 21 (permalink) Old 10-14-2012, 04:41 PM
Such moderate
Doge's Avatar
It looks like its the same on 06's. It just has 6 wires instead of 3. Looks like they all go straight to the ecu.
The wires can't be that long...they are right by the ecu. Id just pull the loom and stuff off and inspect them all. Then retape/loom.
Doge is offline
post #19 of 21 (permalink) Old 10-14-2012, 05:02 PM
Carbon Fiber
FistHammer's Avatar
Duuuude wtf! Talk about bad luck all day!!!
This is a new one too me. Man your gonna understand this car a lot better after you chase all these issues out.
Good luck, I'm sure you'll get it, just be sure to post pics of anything you touched on the car so the smart guys can see what's unplugged or going to the wrong hole!
If brute force is not working you're not using enough.
FistHammer is offline
post #20 of 21 (permalink) Old 10-14-2012, 05:32 PM
Such moderate
Doge's Avatar
thats what she said lol
Doge is offline
